メインコンテンツにスキップ
Reaching the Speaker and Camera in SONY Ericsson W890i Cell Phone
必要な工具と部品
  1. Reaching the Speaker and Camera in SONY Ericsson W890i Cell Phone, Battery: 手順 1、 1の画像 1
    • Flick the two lock tabs into the unlocked positions by pushing each button forward.
  2. Reaching the Speaker and Camera in SONY Ericsson W890i Cell Phone: 手順 2、 1の画像 1
    • Pop the back cover up using the groove on the top of the phone.
  3. Reaching the Speaker and Camera in SONY Ericsson W890i Cell Phone: 手順 3、 1の画像 1
    • You can now access the phone's battery.
    • Using a spudger, remove the battery and set it aside.
  4. Reaching the Speaker and Camera in SONY Ericsson W890i Cell Phone, Speaker or Camera: 手順 4、 2の画像 1 Reaching the Speaker and Camera in SONY Ericsson W890i Cell Phone, Speaker or Camera: 手順 4、 2の画像 2
    • Two rubber buttons cover the bottom two screws. Remove these rubber coverings to access the phone screws.
    • Using a T6 torx wrench, remove the four small screws at the top and bottom corners on the backside of the phone.
  5. Reaching the Speaker and Camera in SONY Ericsson W890i Cell Phone: 手順 5、 1の画像 1
    • Carefully pry off the faceplate using a spudger. Insert the spudger into the middle of the phone.
    • Start near a button and carefully work your way around the phone until the faceplate pops off.
  6. Reaching the Speaker and Camera in SONY Ericsson W890i Cell Phone: 手順 6、 1の画像 1
    • Remove the plastic and metal buttons located around the seam and place off to the side.
    • Be careful not to lose them!
  7. Reaching the Speaker and Camera in SONY Ericsson W890i Cell Phone: 手順 7、 1の画像 1
    • With a tweezer, pry off the back metal plate.
  8. Reaching the Speaker and Camera in SONY Ericsson W890i Cell Phone: 手順 8、 2の画像 1 Reaching the Speaker and Camera in SONY Ericsson W890i Cell Phone: 手順 8、 2の画像 2
    • The speaker and camera combo is accessible after the removal of two small #00 screws. Use the #00 Philips Screwdriver for this step.
    • The piece is now free to move from the phone core.
終わりに
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
Bob
メンバー登録日: 04/15/13
316 ポイント
3のガイドは作成済み
チーム
SUNY Cortland, Team 1-3, Getto Spring 2013 SUNY Cortland, Team 1-3, Getto Spring 2013人のメンバー
SUNYCORT-GETTO-S13S1G3
3 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 825
