メインコンテンツにスキップ
Razer Viper Mini Motherboard Replacement
必要な工具と部品
  1. Razer Viper Mini Motherboard Replacement, Remove Information Sticker: 手順 1、 2の画像 1 Razer Viper Mini Motherboard Replacement, Remove Information Sticker: 手順 1、 2の画像 2
    • Opening the mouse casing will void any warranty that exists for the mouse.
    • Make sure to unplug the mouse before doing anything.
    • Turn the Mouse Over so the bottom is facing up.
    • Remember to take a photo of your serial number or write it down
    • Take off the information sticker and the plastic cover from the bottom of the mouse.
  2. Razer Viper Mini Motherboard Replacement, Remove Baseplate Screws: 手順 2、 2の画像 1 Razer Viper Mini Motherboard Replacement, Remove Baseplate Screws: 手順 2、 2の画像 2
    • Use the Phillips #0 screwdriver to remove the three 2 mm screws from the bottom of the mouse.
    • When removing the screws, unscrew them each slightly and consecutively until you can pull them out with your hands.
  3. Razer Viper Mini Motherboard Replacement, Detach backplate: 手順 3、 3の画像 1 Razer Viper Mini Motherboard Replacement, Detach backplate: 手順 3、 3の画像 2 Razer Viper Mini Motherboard Replacement, Detach backplate: 手順 3、 3の画像 3
    • Use the plastic spudger to gently lift the backplate from the mouse shell.
    • Insert the spudger into the bottom back of the mouse and slowly move it around the mouse to release the backplate.
    • Do not try to push or jab the mouse with the plastic spudger with a large amount of force, this can damage the plating of your mouse.
  4. Razer Viper Mini Motherboard Replacement, Remove shell: 手順 4、 2の画像 1 Razer Viper Mini Motherboard Replacement, Remove shell: 手順 4、 2の画像 2
    • Use the plastic spudger once again to remove the top shell of the mouse.
    • It is similar to the previous step, as you have to pry the plastic spudger gently into the bottom of the mouse and move it slowly inwards and upwards to release the shell.
    • Separating the casing too quickly could damage the ribbon connector between the motherboard and the cable.
  5. Razer Viper Mini Motherboard Replacement, Disconnect the Ribbon Connector: 手順 5、 2の画像 1 Razer Viper Mini Motherboard Replacement, Disconnect the Ribbon Connector: 手順 5、 2の画像 2
    • Disconnect the ribbon connector between the motherboard and the USB cable by squeezing the connector and pulling up.
    • Pulling too hard could damage the wire connections.
    • Pulling by the ribbon instead of the connector can dislocate the wires.
  6. Razer Viper Mini Motherboard Replacement, Unscrew Motherboard from Case: 手順 6、 1の画像 1
    • Use a Phillips #0 screwdriver to remove 2 5.5 and 3 2.5 mm screws.
  7. Razer Viper Mini Motherboard Replacement, Remove Motherboard: 手順 7、 1の画像 1
    • Remove the motherboard by grasping the sides and gently pulling upward.
終わりに
作成者
1人の作成者と共同作成されました。
Addison
メンバー登録日: 08/30/19
3,024 ポイント
17のガイドは作成済み
チーム
University of North Texas, Team S1-G3, Friess Fall 2019 University of North Texas, Team S1-G3, Friess Fall 2019人のメンバー
UNT-FRIESS-F19S1G3
3 メンバー
38のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 14
過去 30 日: 121
今までの合計 2,281
