メインコンテンツにスキップ
Razer Phone Rear Camera Replacement
必要な工具と部品
  1. Razer Phone Rear Camera Replacement, Display Assembly: 手順 1、 3の画像 1 Razer Phone Rear Camera Replacement, Display Assembly: 手順 1、 3の画像 2 Razer Phone Rear Camera Replacement, Display Assembly: 手順 1、 3の画像 3
    • Remove the plastic speaker grills by using the metal spudger to pry underneath the strips.
    • Peel off the plastic speaker grill to reveal the screws.
    • Heating up the plastic grills make them easier to remove.
    • Peeling off the plastic speaker grill will ruin the adhesive used to keep it in place. A new adhesive must be used to put the grill back on the device.
  2. Razer Phone Rear Camera Replacement: 手順 2、 2の画像 1 Razer Phone Rear Camera Replacement: 手順 2、 2の画像 2
    • Pry the top plastic grill off with the metal spudger and reveal the screws.
  3. Razer Phone Rear Camera Replacement: 手順 3、 3の画像 1 Razer Phone Rear Camera Replacement: 手順 3、 3の画像 2 Razer Phone Rear Camera Replacement: 手順 3、 3の画像 3
    • Remove five (two bottom, three top) 2.5 mm screws with the Phillips #000 screwdriver.
    • Remove five (four bottom, one top) 5.5 mm screws with the Torx Head T5 screwdriver.
  4. Razer Phone Rear Camera Replacement: 手順 4、 2の画像 1 Razer Phone Rear Camera Replacement: 手順 4、 2の画像 2
    • Remove the display assembly by using the Jimmy to separate the assembly from the phone's frame.
    • Lift the display assembly away from the other half of the phone.
  5. Razer Phone Rear Camera Replacement: 手順 5、 3の画像 1 Razer Phone Rear Camera Replacement: 手順 5、 3の画像 2 Razer Phone Rear Camera Replacement: 手順 5、 3の画像 3
    • Remove one 2.5 mm screw holding down the metal bracket connector using the Phillips #000 screwdriver.
    • Peel back the metallic shielding over the connector using tweezers.
    • Remove the metal bracket connector.
  6. Razer Phone Rear Camera Replacement: 手順 6、 2の画像 1 Razer Phone Rear Camera Replacement: 手順 6、 2の画像 2
    • Grab hold of the the screen ribbon with the tweezers and remove it from the rest of the phone to free the assembly display.
  7. Razer Phone Rear Camera Replacement, Battery: 手順 7、 3の画像 1 Razer Phone Rear Camera Replacement, Battery: 手順 7、 3の画像 2 Razer Phone Rear Camera Replacement, Battery: 手順 7、 3の画像 3
    • Grab hold of the connector on the right side of the phone (just above the battery) using the tweezers.
    • Remove the connector.
  8. Razer Phone Rear Camera Replacement: 手順 8、 2の画像 1 Razer Phone Rear Camera Replacement: 手順 8、 2の画像 2
    • Remove the 2.5 mm screw holding down the bracket with a Phillips #000 screwdriver.
    • Grab the bracket with the tweezers and remove it.
  9. Razer Phone Rear Camera Replacement: 手順 9、 3の画像 1 Razer Phone Rear Camera Replacement: 手順 9、 3の画像 2 Razer Phone Rear Camera Replacement: 手順 9、 3の画像 3
    • Peel off and pull out the elastic tabs at the bottom of the battery.
  10. Razer Phone Rear Camera Replacement: 手順 10、 2の画像 1 Razer Phone Rear Camera Replacement: 手順 10、 2の画像 2
    • Carefully use the Jimmy to wedge the battery out of the phone.
  11. Razer Phone Rear Camera Replacement, Charging Port: 手順 11、 2の画像 1 Razer Phone Rear Camera Replacement, Charging Port: 手順 11、 2の画像 2
    • Using a Phillips #000 screwdriver, take out the seven 1 mm screws on the bottom panel of the device.
    • There are a few gold brackets under some of the screws. Make sure to remove these and keep them for reassembly.
  12. Razer Phone Rear Camera Replacement: 手順 12、 2の画像 1 Razer Phone Rear Camera Replacement: 手順 12、 2の画像 2
    • Grab hold of the blue connector on the upper left side of the phone with the tweezers.
  13. Razer Phone Rear Camera Replacement: 手順 13、 2の画像 1 Razer Phone Rear Camera Replacement: 手順 13、 2の画像 2
    • Use the tweezers to grab hold of the connector for the blue wire (bottom of the device), and remove the connector.
    • Use the tweezers to grab hold of the connector for the white wire, and remove the connector.
  14. Razer Phone Rear Camera Replacement: 手順 14、 1の画像 1
    • Using the tweezers, grab the detached charging port and ribbon.
  15. Razer Phone Rear Camera Replacement, Rear Camera: 手順 15、 2の画像 1 Razer Phone Rear Camera Replacement, Rear Camera: 手順 15、 2の画像 2
    • Remove the one 2.5 mm screw with the Phillips #000 screwdriver.
  16. Razer Phone Rear Camera Replacement: 手順 16、 3の画像 1 Razer Phone Rear Camera Replacement: 手順 16、 3の画像 2 Razer Phone Rear Camera Replacement: 手順 16、 3の画像 3
    • Remove the protective peel covering the rear cameras using your hands.
  17. Razer Phone Rear Camera Replacement: 手順 17、 1の画像 1
    • Use the tweezers to remove the white tab connector.
  18. Razer Phone Rear Camera Replacement: 手順 18、 1の画像 1
    • Grab and remove the metal tab with the tweezers.
  19. Razer Phone Rear Camera Replacement: 手順 19、 3の画像 1 Razer Phone Rear Camera Replacement: 手順 19、 3の画像 2 Razer Phone Rear Camera Replacement: 手順 19、 3の画像 3
    • Grab the connectors with the tweezers and gently lift the connectors loose.
  20. Razer Phone Rear Camera Replacement: 手順 20、 2の画像 1 Razer Phone Rear Camera Replacement: 手順 20、 2の画像 2
  21. Razer Phone Rear Camera Replacement: 手順 21、 1の画像 1
    • Remove the one 2.5 mm screw underneath the connectors with the Phillips #000 screwdriver.
  22. Razer Phone Rear Camera Replacement: 手順 22、 3の画像 1 Razer Phone Rear Camera Replacement: 手順 22、 3の画像 2 Razer Phone Rear Camera Replacement: 手順 22、 3の画像 3
    • Grab the loose connectors with a tweezer and gently remove the rear camera unit from the phone.
終わりに
作成者
2人の作成者と共同で作成されました。
Kenny Lau
メンバー登録日: 01/24/19
182 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team S19-G6, White Winter 2019 Cal Poly, Team S19-G6, White Winter 2019人のメンバー
CPSU-WHITE-W19S19G6
5 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 1,287
