はじめに
Is your Razer Phone's speaker blown? If so, here is the guide to replacing it.
必要な工具と部品
Remove the plastic speaker grills by using the metal spudger to pry underneath the strips.
Peel off the plastic speaker grill to reveal the screws.
Grab hold of the connector on the right side of the phone (just above the battery) using the tweezers.
Remove the connector.
Using a Phillips #000 screwdriver, take out the seven 1 mm screws on the bottom panel of the device.
2 の人々がこのガイドを完成させました。
