はじめに
Having troubles charging your Razer Phone and need to replace the charging port? Follow this easy guide on how to do so.
必要な工具と部品
Remove the plastic speaker grills by using the metal spudger to pry underneath the strips.
Peel off the plastic speaker grill to reveal the screws.
Using a Phillips #000 screwdriver, take out the seven 1 mm screws on the bottom panel of the device.
14 の人々がこのガイドを完成させました。
10 件のコメント
Search it on Amazon.c
hi how much you guys charge for the charging port thanks
