メインコンテンツにスキップ
はじめに
This guide will cover how to open the Razer Ouroboros mouse, remove the existing scroll wheel, and replace it with a new one.
Note: Make sure the device is unplugged and powered off before continuing with this guide.
  1. Use a Phillips #00 screwdriver to loosen the two captive screws from the bottom of the mouse. Slide the palm rest out of place. Slide the palm rest out of place.
    • Use a Phillips #00 screwdriver to loosen the two captive screws from the bottom of the mouse.
    • Slide the palm rest out of place.
  2. Remove all of the stickers on the back of the mouse. After doing so, you should see six screws on the back of the mouse. Use the Phillips #0 Screwdriver to remove all six of these 4mm screws.
    • Remove all of the stickers on the back of the mouse. After doing so, you should see six screws on the back of the mouse.
    • Use the Phillips #0 Screwdriver to remove all six of these 4mm screws.
    • Use the Phillips #00 Screwdriver to remove these two, 3mm screws.
    • Slide the side panels off of the mouse.
    • Use your tweezers to take the lock switches off of the mouse.
    • Using the T6 Torx screwdriver, remove the two bottom 4mm screws as indicated in the second picture.
  3. Using the T6 Torx screwdriver, remove the two 4mm screws hidden in the deep holes indicated in the first picture. Slide the top panels off of the mouse. Flip the mouse over, and the mouse casing should come off.
    • Using the T6 Torx screwdriver, remove the two 4mm screws hidden in the deep holes indicated in the first picture.
    • Slide the top panels off of the mouse.
    • Flip the mouse over, and the mouse casing should come off.
    • There are some connectors connecting the casing to the motherboard. They should slide off. Just be careful not to break them.
  4. Locate the 4mm screw indicated in the first picture, use a Phillips #00 Screwdriver to remove it. Locate the two 4mm screws in the second picture, and remove those two with a Phillips #0 Screwdriver. Now, you may remove the board that holds the scroll wheel and its components. Simply slide the wheel out and replace it.
    • Locate the 4mm screw indicated in the first picture, use a Phillips #00 Screwdriver to remove it.
    • Locate the two 4mm screws in the second picture, and remove those two with a Phillips #0 Screwdriver.
    • Now, you may remove the board that holds the scroll wheel and its components. Simply slide the wheel out and replace it.
    • Take note of the orientation in the final picture so that you can place the wheel back correctly into its mechanism.
終わりに
5 の人々がこのガイドを完成させました。
Preston Darling
メンバー登録日: 2016年07月26日
372 ポイント
2のガイドは作成済み
チーム
University of Memphis, Team 1-2, Kim SU 2016 University of Memphis, Team 1-2, Kim SU 2016人のメンバー
UM-KIM-SU16S1G2
3 メンバー
4のガイドは作成済み
コメント1件
Hello, one question, did the scroll click break, is it the same procedure?
Jorge Bestani (Ayman) - 返信
コメントを追加
統計データを表示:
過去 24時間: 1
過去 7 日: 13
過去 30 日: 58
今までの合計 3,418
