はじめに
This guide will cover how to open the Razer Ouroboros mouse, remove the existing scroll wheel, and replace it with a new one.
Note: Make sure the device is unplugged and powered off before continuing with this guide.
必要な工具と部品
Use a Phillips #00 screwdriver to loosen the two captive screws from the bottom of the mouse.
Slide the palm rest out of place.
この手順で使用する道具:Tweezers$4.99
Remove all of the stickers on the back of the mouse. After doing so, you should see six screws on the back of the mouse.
Use the Phillips #0 Screwdriver to remove all six of these 4mm screws.
Use the Phillips #00 Screwdriver to remove these two, 3mm screws.
Slide the side panels off of the mouse.
Use your tweezers to take the lock switches off of the mouse.
Using the T6 Torx screwdriver, remove the two bottom 4mm screws as indicated in the second picture.
Locate the 4mm screw indicated in the first picture, use a Phillips #00 Screwdriver to remove it.
Locate the two 4mm screws in the second picture, and remove those two with a Phillips #0 Screwdriver.
Now, you may remove the board that holds the scroll wheel and its components. Simply slide the wheel out and replace it.
5 の人々がこのガイドを完成させました。
1件のガイドコメント
Hello, one question, did the scroll click break, is it the same procedure?
