メインコンテンツにスキップ
Razer Ouroboros Scroll Wheel Replacement
必要な工具と部品
  1. Razer Ouroboros Scroll Wheel Replacement, Scroll Wheel: 手順 1、 3の画像 1 Razer Ouroboros Scroll Wheel Replacement, Scroll Wheel: 手順 1、 3の画像 2 Razer Ouroboros Scroll Wheel Replacement, Scroll Wheel: 手順 1、 3の画像 3
    • Use a Phillips #00 screwdriver to loosen the two captive screws from the bottom of the mouse.
    • Slide the palm rest out of place.
  2. Razer Ouroboros Scroll Wheel Replacement: 手順 2、 2の画像 1 Razer Ouroboros Scroll Wheel Replacement: 手順 2、 2の画像 2
    • Remove all of the stickers on the back of the mouse. After doing so, you should see six screws on the back of the mouse.
    • Use the Phillips #0 Screwdriver to remove all six of these 4mm screws.
    • Use the Phillips #00 Screwdriver to remove these two, 3mm screws.
    • Slide the side panels off of the mouse.
    • Use your tweezers to take the lock switches off of the mouse.
    • Using the T6 Torx screwdriver, remove the two bottom 4mm screws as indicated in the second picture.
  3. Razer Ouroboros Scroll Wheel Replacement: 手順 3、 3の画像 1 Razer Ouroboros Scroll Wheel Replacement: 手順 3、 3の画像 2 Razer Ouroboros Scroll Wheel Replacement: 手順 3、 3の画像 3
    • Using the T6 Torx screwdriver, remove the two 4mm screws hidden in the deep holes indicated in the first picture.
    • Slide the top panels off of the mouse.
    • Flip the mouse over, and the mouse casing should come off.
    • There are some connectors connecting the casing to the motherboard. They should slide off. Just be careful not to break them.
  4. Razer Ouroboros Scroll Wheel Replacement: 手順 4、 3の画像 1 Razer Ouroboros Scroll Wheel Replacement: 手順 4、 3の画像 2 Razer Ouroboros Scroll Wheel Replacement: 手順 4、 3の画像 3
    • Locate the 4mm screw indicated in the first picture, use a Phillips #00 Screwdriver to remove it.
    • Locate the two 4mm screws in the second picture, and remove those two with a Phillips #0 Screwdriver.
    • Now, you may remove the board that holds the scroll wheel and its components. Simply slide the wheel out and replace it.
    • Take note of the orientation in the final picture so that you can place the wheel back correctly into its mechanism.
終わりに
5 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Preston Darling
メンバー登録日: 07/26/16
372 ポイント
2のガイドは作成済み
チーム
University of Memphis, Team 1-2, Kim SU 2016 University of Memphis, Team 1-2, Kim SU 2016人のメンバー
UM-KIM-SU16S1G2
3 メンバー
4のガイドは作成済み
コメント 1 件
Hello, one question, did the scroll click break, is it the same procedure?
Jorge Bestani (Ayman) - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 14
今までの合計 4,166
