この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
From time to time, the rechargeable battery in this mouse will need to be replaced. This replacement is quite simple and straight forward. Only one piece must be removed in order to access the battery. Please note, this device can only use rechargeable batteries. If there has been damage to the battery, contacting the Razer Tech support is the best option.
For this job, you will need the PH 00 screwdriver. That is the only tool needed here.
必要な工具と部品
Begin by turning the mouse upside down.
Loosen the two captive screws circled in the first image.
Slide the palm rest toward the back of the mouse. It should slide down its track and come right off.
7 の人々がこのガイドを完成させました。
8 件のコメント
is the battery a standard AA battery size or did they use a different size?
adiforipod - 返信
… what happens if I don't use a rechargeable battery?
Its fine… You just need to remember not to put it on the recharging base… and the battery will be basically dead after 24 hour use.
will any brand battery work or does the stock one have specific specs?
