メインコンテンツにスキップ
Razer Ouroboros Battery Replacement
必要な工具と部品
  1. Razer Ouroboros Battery Replacement, Battery: 手順 1、 1の画像 1
    • Begin by turning the mouse upside down.
    • Use a Phillips #00 to loosen the two captive screws circled in the first image.
    • These screws do NOT come out, they merely loosen.
    • Slide the palm rest toward the back of the mouse. It should slide down its track and come right off.
    There’s also a version that has no screws to undo, just disregard the second step and follow the rest of the guide
    Bryan Russ - 返信
  2. Razer Ouroboros Battery Replacement: 手順 2、 1の画像 1
    • This is the bottom of the palm rest.
    • Turn the knob highlighted by the red circle will change the height of the palm rest for maximum comfort.
  3. Razer Ouroboros Battery Replacement: 手順 3、 1の画像 1
    • The battery compartment is on the back side and is easily viewed once the palm rest is removed. Simply push up gently and the hinged battery door opens from the bottom
    • Place the new battery into circular slot shown in the picture. The battery should be placed in positive side first.
    • You must use rechargeable batteries in this mouse.
終わりに
7 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Brandon Jones
メンバー登録日: 07/19/16
308 ポイント
1ガイドが承認済み
チーム
University of Memphis, Team 1-2, Kim SU 2016 University of Memphis, Team 1-2, Kim SU 2016人のメンバー
UM-KIM-SU16S1G2
3 メンバー
4のガイドは作成済み
8 件のコメント
is the battery a standard AA battery size or did they use a different size?
adiforipod - 返信
Standard AA size mate
Minty Fox - 返信
… what happens if I don't use a rechargeable battery?
Russell Phillips - 返信
Its fine… You just need to remember not to put it on the recharging base… and the battery will be basically dead after 24 hour use.
flamespinner1 -
will any brand battery work or does the stock one have specific specs?
ThrowsMachete - 返信
I don’t have the screws on the bottom of my mouse wtf!
Miika mon - 返信
The screws don’t actually need to be removed you only need to hold down the button that adjusts the length.
Shane Madden - 返信
You should specify that this mouse uses NiMH and not Li-ion batteries.
Samuel Hunter Logan - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 13
過去 30 日: 54
今までの合計 19,738
