メインコンテンツにスキップ
Razer Naga Epic Chroma Side Button Connection Strip Replacement
必要な工具と部品
  1. Razer Naga Epic Chroma Side Button Connection Strip Replacement, Razer Naga Epic Chroma Disassembly: 手順 1、 1の画像 1
    • Using a spudger, remove the teflon tape on the bottom of the mouse to reveal four screws.
  2. Razer Naga Epic Chroma Side Button Connection Strip Replacement: 手順 2、 1の画像 1
    • Use a Phillips #00 screwdriver to remove the four screws.
  3. Razer Naga Epic Chroma Side Button Connection Strip Replacement: 手順 3、 1の画像 1
    • Gently pull on the top plastic plate of the device and carefully unplug the white cord from the circuit board.
    • When removing the chassis, carefully unplug the cord connecting to the top mouse buttons.
  4. Razer Naga Epic Chroma Side Button Connection Strip Replacement: 手順 4、 1の画像 1
    • Gently pull up on the right plate on the mouse; separating it.
    • Carefully repeat this step for the left side.
    • Be wary of the cable connecting to the twelve mouse buttons located on the left plate. This can be disconnected if needed.
  5. Razer Naga Epic Chroma Side Button Connection Strip Replacement, Battery: 手順 5、 1の画像 1
    • Take your nylon spudger to gently pry the battery pack from the device.
    • Remove the foam on the battery shell for your new battery.
  6. Razer Naga Epic Chroma Side Button Connection Strip Replacement: 手順 6、 1の画像 1
    • Unplug the power cord from the circuit board in the mouse.
  7. Razer Naga Epic Chroma Side Button Connection Strip Replacement: 手順 7、 1の画像 1
    • Plug the cord of the new battery into the socket found in the bottom right of the circuit board.
    • Insert the new battery into the battery socket.
    • Place the foam on the surface of the new battery (reference Step 5).
  8. Razer Naga Epic Chroma Side Button Connection Strip Replacement, Side Button Connection Strip: 手順 8、 1の画像 1
    • Under the battery, remove the two screws holding the battery mount in place.
    • Remove the battery mount.
  9. Razer Naga Epic Chroma Side Button Connection Strip Replacement: 手順 9、 1の画像 1
    • Flip open the black pieces on either end of the white connection strip holding the side buttons onto the circuit board.
  10. Razer Naga Epic Chroma Side Button Connection Strip Replacement: 手順 10、 1の画像 1
    • Gently pull the white connection strip out of both connection ports.
  11. Razer Naga Epic Chroma Side Button Connection Strip Replacement: 手順 11、 1の画像 1
    • Insert the blue stripes of the new white connection strip into both white connection points.
    • One connection point is on the plastic plate that has the buttons. The second connection point is where the battery mount was.
終わりに
作成者
2人の作成者と共同で作成されました。
Jordan Morgan
メンバー登録日: 01/19/17
895 ポイント
6のガイドは作成済み
チーム
Arkansas State University, Team 1-4, Chamberlain Spring 2017 Arkansas State University, Team 1-4, Chamberlain Spring 2017人のメンバー
ARSU-CHAMBERLAIN-S17S1G4
4 メンバー
6のガイドは作成済み
2 件のコメント
Where can i buy a new Strip?
Rathura - 返信
Did you find the strip? Im looking or it as well.
Tsuki Yomi -
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 9
今までの合計 2,666
