メインコンテンツにスキップ
Razer Naga Epic Chroma Disassembly
必要な工具と部品
  1. Razer Naga Epic Chroma Disassembly, Razer Naga Epic Chroma Disassembly: 手順 1、 1の画像 1
    • Using a spudger, remove the teflon tape on the bottom of the mouse to reveal four screws.
  2. Razer Naga Epic Chroma Disassembly: 手順 2、 1の画像 1
    • Use a Phillips #00 screwdriver to remove the four screws.
  3. Razer Naga Epic Chroma Disassembly: 手順 3、 1の画像 1
    • Gently pull on the top plastic plate of the device and carefully unplug the white cord from the circuit board.
    • When removing the chassis, carefully unplug the cord connecting to the top mouse buttons.
  4. Razer Naga Epic Chroma Disassembly: 手順 4、 1の画像 1
    • Gently pull up on the right plate on the mouse; separating it.
    • Carefully repeat this step for the left side.
    • Be wary of the cable connecting to the twelve mouse buttons located on the left plate. This can be disconnected if needed.
終わりに
13 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Jordan Morgan
メンバー登録日: 01/19/17
895 ポイント
6のガイドは作成済み
チーム
Arkansas State University, Team 1-4, Chamberlain Spring 2017 Arkansas State University, Team 1-4, Chamberlain Spring 2017人のメンバー
ARSU-CHAMBERLAIN-S17S1G4
4 メンバー
6のガイドは作成済み
3 件のコメント
where can i get new teflon tape ???
Kieran jones - 返信
This guide is excellent, to further it, you must take out another screw near the battery compartment and 2 on the inside of the compartment to completely take off the board to be able to clean the lense if you are having random mouse jumps and non responsiveness from the mouse, I did that and now it works like new after re-assembly. I used 70% alcohol with cotton swabs to thoroughly clean everything including the lens.
King Gosuto - 返信
Hi, can you please tell me where can I find a grip (right side) for my Razer Naga Epic mouse.
Ghufran Muhammad -
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 25
過去 30 日: 113
今までの合計 25,685
