メインコンテンツにスキップ
Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair
必要な工具と部品
  1. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair, Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair: 手順 1、 3の画像 1 Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair, Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair: 手順 1、 3の画像 2 Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair, Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair: 手順 1、 3の画像 3
    • To get to the maelstrom wiring you must first pull off the plastic cover.
    • To do this roll the maelstrom over so the rubber cover on the back is facing up. The rubber pad simply peels off exposing the metal backplate.
    • Then remove the four 8.5mm screws on the back plate of the maelstrom.
  2. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair: 手順 2、 2の画像 1 Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair: 手順 2、 2の画像 2
    • Once the four screws are removed, the top cover can be lifted off.
    • There is a ribbon wire connecting the volume wheel to the circuit board. This is not permanently attached, and can be plugged back in if it gets pulled out.
    • Remove the three 2mm screws from the circuit board to separate it from the back plate.
  3. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair: 手順 3、 2の画像 1 Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair: 手順 3、 2の画像 2
    • The circuit board is now completely separate from the housing and the wires can now be inspected.
    • Peel back the tape on the wires to inspect any damage to the wires if there is any.
終わりに
6 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Kyle Schober
メンバー登録日: 02/24/14
640 ポイント
5のガイドは作成済み
チーム
Michigan Tech, Team 5-8, Lauer Spring 2014 Michigan Tech, Team 5-8, Lauer Spring 2014人のメンバー
MTU-LAUER-S14S5G8
3 メンバー
13のガイドは作成済み
4 件のコメント
Well for the last step the wires I peeled the wires by burning them on a gas ranger. Worked Perfectly.
Edwin Lopez - 返信
can you provide the connection map for the cables that go prom remote root to headphones?
johnny1992black - 返信
comeon you wanna tell me you took picture of the cables from one side and the other one not this is a joke right?
muchas gracias por este articulo, es el 2020 y me a servido mucho para arreglar mis audifonos
diego.riquelme.cortes - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 15
今までの合計 5,950
