メインコンテンツにスキップ
Razer DeathAdder Chroma Optical Sensor Replacement
必要な工具と部品
  1. Razer DeathAdder Chroma Optical Sensor Replacement, Outer Casing: 手順 1、 1の画像 1
    • Opening the mouse casing will void any warranty that exists for the mouse.
    • Turn the mouse over so the bottom is facing up.
  2. Razer DeathAdder Chroma Optical Sensor Replacement: 手順 2、 2の画像 1 Razer DeathAdder Chroma Optical Sensor Replacement: 手順 2、 2の画像 2
    • Use the blunt end of the spudger to pry the adhesive rubber pads from the top left and right edges.
  3. Razer DeathAdder Chroma Optical Sensor Replacement: 手順 3、 2の画像 1 Razer DeathAdder Chroma Optical Sensor Replacement: 手順 3、 2の画像 2
    • Use a Phillips #0 screwdriver to remove two 6.7 mm screws.
  4. Razer DeathAdder Chroma Optical Sensor Replacement: 手順 4、 1の画像 1
    • Use your fingers to identify the location of the screw under the bottom label.
  5. Razer DeathAdder Chroma Optical Sensor Replacement: 手順 5、 1の画像 1
    • Use a Phillips #0 screwdriver to remove one 6.7 mm screw.
    • Clear the label away from around the screw for easier removal.
  6. Razer DeathAdder Chroma Optical Sensor Replacement: 手順 6、 3の画像 1 Razer DeathAdder Chroma Optical Sensor Replacement: 手順 6、 3の画像 2 Razer DeathAdder Chroma Optical Sensor Replacement: 手順 6、 3の画像 3
    • Turn the mouse over so the bottom is facing down.
    • Separate the top casing from the bottom base by pulling the top casing upwards.
    • Separating the casing too quickly could damage the ribbon connector between the motherboard and the LED lights.
  7. Razer DeathAdder Chroma Optical Sensor Replacement: 手順 7、 2の画像 1 Razer DeathAdder Chroma Optical Sensor Replacement: 手順 7、 2の画像 2
    • Disconnect the ribbon connector between the motherboard and the LED lights by pulling upward.
    • Pulling too hard could damage the wire connections.
  8. Razer DeathAdder Chroma Optical Sensor Replacement, Motherboard: 手順 8、 2の画像 1 Razer DeathAdder Chroma Optical Sensor Replacement, Motherboard: 手順 8、 2の画像 2
    • Disconnect the ribbon connector between the motherboard and the USB cable by pulling upward.
  9. Razer DeathAdder Chroma Optical Sensor Replacement: 手順 9、 1の画像 1
    • Use a Phillips #0 screwdriver to remove three 5.5 mm screws.
  10. Razer DeathAdder Chroma Optical Sensor Replacement: 手順 10、 2の画像 1 Razer DeathAdder Chroma Optical Sensor Replacement: 手順 10、 2の画像 2
    • Use a Phillips #0 screwdriver to remove two 11.5 mm screws on the side buttons.
  11. Razer DeathAdder Chroma Optical Sensor Replacement: 手順 11、 1の画像 1
    • Use a Phillips #000 screwdriver to remove one 5.0 mm screw.
  12. Razer DeathAdder Chroma Optical Sensor Replacement: 手順 12、 2の画像 1 Razer DeathAdder Chroma Optical Sensor Replacement: 手順 12、 2の画像 2
    • Disconnect the ribbon connector between the motherboard and the optical sensor.
  13. Razer DeathAdder Chroma Optical Sensor Replacement: 手順 13、 2の画像 1 Razer DeathAdder Chroma Optical Sensor Replacement: 手順 13、 2の画像 2
    • Remove the motherboard by grasping the sides and gently pulling upward.
  14. Razer DeathAdder Chroma Optical Sensor Replacement, Optical Sensor: 手順 14、 2の画像 1 Razer DeathAdder Chroma Optical Sensor Replacement, Optical Sensor: 手順 14、 2の画像 2
    • Use a Phillips #0 screwdriver to remove two 5.5mm screws.
  15. Razer DeathAdder Chroma Optical Sensor Replacement: 手順 15、 2の画像 1 Razer DeathAdder Chroma Optical Sensor Replacement: 手順 15、 2の画像 2
    • Remove the optical sensor by pulling it forward and up.
終わりに
5 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Nathan D. Kappler
メンバー登録日: 03/27/17
343 ポイント
2のガイドは作成済み
チーム
Baylor, Team S5-G2, Williams Spring 2017 Baylor, Team S5-G2, Williams Spring 2017人のメンバー
BU-WILLIAMS-S17S5G2
3 メンバー
6のガイドは作成済み
2 件のコメント
Where do I get the part?
youarestaringatme - 返信
This is not a sensor, but a sensor backlight. Sensor on the underside of the main board
Guest Night - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 24
今までの合計 6,237
