メインコンテンツにスキップ
Razer Blade Stealth 2017 Keyboard Replacement
必要な工具と部品
  1. Razer Blade Stealth 2017 Keyboard Replacement, Battery: 手順 1、 2の画像 1 Razer Blade Stealth 2017 Keyboard Replacement, Battery: 手順 1、 2の画像 2
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
    • Whenever you remove screws from the device, remember to save and label them.
  2. Razer Blade Stealth 2017 Keyboard Replacement: 手順 2、 1の画像 1
    • Remove the bottom cover of the laptop by sliding it away from the hinge.
    • Do not force the cover up!
  3. Razer Blade Stealth 2017 Keyboard Replacement: 手順 3、 2の画像 1 Razer Blade Stealth 2017 Keyboard Replacement: 手順 3、 2の画像 2
    • Use your fingernail to pry up and disconnect the battery from the motherboard.
  4. Razer Blade Stealth 2017 Keyboard Replacement: 手順 4、 1の画像 1
    • Use a Phillips #00 screwdriver to remove the six, 5mm screws securing the battery.
  5. Razer Blade Stealth 2017 Keyboard Replacement: 手順 5、 2の画像 1 Razer Blade Stealth 2017 Keyboard Replacement: 手順 5、 2の画像 2
    • Remove any tape attached to the battery.
    • Use the plastic spudger to pry out the battery.
  6. Razer Blade Stealth 2017 Keyboard Replacement, Motherboard: 手順 6、 3の画像 1 Razer Blade Stealth 2017 Keyboard Replacement, Motherboard: 手順 6、 3の画像 2 Razer Blade Stealth 2017 Keyboard Replacement, Motherboard: 手順 6、 3の画像 3
    • Use a plastic spudger to gently undo the connections to the motherboard.
  7. Razer Blade Stealth 2017 Keyboard Replacement: 手順 7、 3の画像 1 Razer Blade Stealth 2017 Keyboard Replacement: 手順 7、 3の画像 2 Razer Blade Stealth 2017 Keyboard Replacement: 手順 7、 3の画像 3
    • Use a Phillips #00 screwdriver to remove the six 4 mm screws holding the display hinges on both side.
    • Remove the small plastic brackets holding the display hinges.
  8. Razer Blade Stealth 2017 Keyboard Replacement: 手順 8、 1の画像 1
    • Remove the 2.6 mm screw holding the Wi-Fi card down with a Phillips #00 screwdriver.
    • Remove the motherboard from the laptop.
  9. Razer Blade Stealth 2017 Keyboard Replacement, Keyboard: 手順 9、 2の画像 1 Razer Blade Stealth 2017 Keyboard Replacement, Keyboard: 手順 9、 2の画像 2
    • Carefully remove tape from the keyboard.
  10. Razer Blade Stealth 2017 Keyboard Replacement: 手順 10、 2の画像 1 Razer Blade Stealth 2017 Keyboard Replacement: 手順 10、 2の画像 2
    • Pull out the cables carefully.
  11. Razer Blade Stealth 2017 Keyboard Replacement: 手順 11、 2の画像 1 Razer Blade Stealth 2017 Keyboard Replacement: 手順 11、 2の画像 2
    • Use a Phillips #000 screwdriver to remove the fifty-five 1.6mm screws securing the keyboard.
    • Not all the screws are highlighted.
  12. Razer Blade Stealth 2017 Keyboard Replacement: 手順 12、 3の画像 1 Razer Blade Stealth 2017 Keyboard Replacement: 手順 12、 3の画像 2 Razer Blade Stealth 2017 Keyboard Replacement: 手順 12、 3の画像 3
    • Carefully pick up the keyboard from both sides in order to remove the keyboard.
    • Use a spudger if necessary to remove the keyboard.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Nolan Wilkins
メンバー登録日: 02/08/24
109 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team 5-1, Coppersmith Spring 2024 University of North Texas, Team 5-1, Coppersmith Spring 2024人のメンバー
UNT-COPPERSMITH-S24S5G1
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 52
