はじめに
This guide outlines how to replace the HDMI and USB-A port module in the Razer Blade Stealth 2017. When and external device is connected to the HDMI port, if the external device is not displaying audio or visual feed, the HDMI may be broken. The HDMI and USB-A module is located on the right-hand side of the computer, and often experience issues with loose ports and external device communication. Some tools are required for this replacement.
必要な工具と部品
Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
Use a plastic spudger to lift up the press-fit interconnect cable and expose the USB-A and HDMI port module.
