メインコンテンツにスキップ
Razer Blade Stealth 2017 Display Assembly Replacement
必要な工具と部品
  1. Razer Blade Stealth 2017 Display Assembly Replacement, Battery: 手順 1、 2の画像 1 Razer Blade Stealth 2017 Display Assembly Replacement, Battery: 手順 1、 2の画像 2
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
    • Whenever you remove screws from the device, remember to save and label them.
  2. Razer Blade Stealth 2017 Display Assembly Replacement: 手順 2、 1の画像 1
    • Remove the bottom cover of the laptop by sliding it away from the hinge.
    • Do not force the cover up!
  3. Razer Blade Stealth 2017 Display Assembly Replacement: 手順 3、 2の画像 1 Razer Blade Stealth 2017 Display Assembly Replacement: 手順 3、 2の画像 2
    • Use your fingernail to pry up and disconnect the battery from the motherboard.
  4. Razer Blade Stealth 2017 Display Assembly Replacement: 手順 4、 1の画像 1
    • Use a Phillips #00 screwdriver to remove the six, 5mm screws securing the battery.
  5. Razer Blade Stealth 2017 Display Assembly Replacement: 手順 5、 2の画像 1 Razer Blade Stealth 2017 Display Assembly Replacement: 手順 5、 2の画像 2
    • Remove any tape attached to the battery.
    • Use the plastic spudger to pry out the battery.
  6. Razer Blade Stealth 2017 Display Assembly Replacement, Display Assembly: 手順 6、 2の画像 1 Razer Blade Stealth 2017 Display Assembly Replacement, Display Assembly: 手順 6、 2の画像 2
    • Use a Phillips #00 screwdriver to remove the six 4 mm screws securing the display assembly.
  7. Razer Blade Stealth 2017 Display Assembly Replacement: 手順 7、 3の画像 1 Razer Blade Stealth 2017 Display Assembly Replacement: 手順 7、 3の画像 2 Razer Blade Stealth 2017 Display Assembly Replacement: 手順 7、 3の画像 3
    • Use the plastic spudger to remove the plastic brackets beneath the hinges.
  8. Razer Blade Stealth 2017 Display Assembly Replacement: 手順 8、 2の画像 1 Razer Blade Stealth 2017 Display Assembly Replacement: 手順 8、 2の画像 2
    • Remove any tape attached to the wires.
    • Use the plastic spudger to slide the connectors to the right to disconnect them.
  9. Razer Blade Stealth 2017 Display Assembly Replacement: 手順 9、 2の画像 1 Razer Blade Stealth 2017 Display Assembly Replacement: 手順 9、 2の画像 2
    • Use the plastic spudger to lift the connector off of the socket.
  10. Razer Blade Stealth 2017 Display Assembly Replacement: 手順 10、 2の画像 1 Razer Blade Stealth 2017 Display Assembly Replacement: 手順 10、 2の画像 2
    • Use your fingers to lift connectors off of their sockets.
  11. Razer Blade Stealth 2017 Display Assembly Replacement: 手順 11、 2の画像 1 Razer Blade Stealth 2017 Display Assembly Replacement: 手順 11、 2の画像 2
    • Lift the screen to the open position.
    • Remove the display assembly by sliding it away from the keyboard.
    • Do not force the display assembly off!
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Kris Ritter
メンバー登録日: 02/08/24
173 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team 5-1, Coppersmith Spring 2024 University of North Texas, Team 5-1, Coppersmith Spring 2024人のメンバー
UNT-COPPERSMITH-S24S5G1
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 13
過去 30 日: 28
今までの合計 76
