メインコンテンツにスキップ
Razer Blade Stealth 2017 Audio and USB-A Port Replacement
必要な工具と部品
  1. Razer Blade Stealth 2017 Audio and USB-A Port Replacement, Battery: 手順 1、 2の画像 1 Razer Blade Stealth 2017 Audio and USB-A Port Replacement, Battery: 手順 1、 2の画像 2
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
    • Whenever you remove screws from the device, remember to save and label them.
  2. Razer Blade Stealth 2017 Audio and USB-A Port Replacement: 手順 2、 1の画像 1
    • Remove the bottom cover of the laptop by sliding it away from the hinge.
    • Do not force the cover up!
  3. Razer Blade Stealth 2017 Audio and USB-A Port Replacement: 手順 3、 2の画像 1 Razer Blade Stealth 2017 Audio and USB-A Port Replacement: 手順 3、 2の画像 2
    • Use your fingernail to pry up and disconnect the battery from the motherboard.
  4. Razer Blade Stealth 2017 Audio and USB-A Port Replacement: 手順 4、 1の画像 1
    • Use a Phillips #00 screwdriver to remove the six, 5mm screws securing the battery.
  5. Razer Blade Stealth 2017 Audio and USB-A Port Replacement: 手順 5、 2の画像 1 Razer Blade Stealth 2017 Audio and USB-A Port Replacement: 手順 5、 2の画像 2
    • Remove any tape attached to the battery.
    • Use the plastic spudger to pry out the battery.
  6. Razer Blade Stealth 2017 Audio and USB-A Port Replacement, Audio and USB-A Port: 手順 6、 2の画像 1 Razer Blade Stealth 2017 Audio and USB-A Port Replacement, Audio and USB-A Port: 手順 6、 2の画像 2
    • Use a plastic spudger to lift up the module connector.
  7. Razer Blade Stealth 2017 Audio and USB-A Port Replacement: 手順 7、 2の画像 1 Razer Blade Stealth 2017 Audio and USB-A Port Replacement: 手順 7、 2の画像 2
    • Use a Phillips #00 screwdriver to remove the two, 3mm screws from the USB-A and audio port module.
  8. Razer Blade Stealth 2017 Audio and USB-A Port Replacement: 手順 8、 1の画像 1
    • Use a plastic spudger to remove the USB-A and audio port module from the chassis.
終わりに
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
Helene Willits
メンバー登録日: 10/10/19
762 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team S11-G3, Regan Fall 2019 Cal Poly, Team S11-G3, Regan Fall 2019人のメンバー
CPSU-REGAN-F19S11G3
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 13
今までの合計 1,701
