はじめに
The heat sink is in charge of dissipating heat from within your computer’s housing unit to prevent your CPU from being damaged.
A faulty heat sink will likely overheat your computer’s CPU and destroy many components, resulting in the loss of information, and an inability to access various drives on your computer.
If you notice your laptop getting abnormally hot, or if the fans are constantly running, then your laptop may have a faulty heat sink.
Follow these 8 steps in order to successfully replace the heat sink in a Razer Blade Stealth 2016 laptop.
Be sure that the laptop is powered off before beginning.
必要な工具と部品
Use a Torx (T5) screwdriver to remove the eight 3 mm screws on the back case.
Remove the rear cover by prying up lightly starting in one of the corners.
Remove the four 3.38 mm screws around the black square using a Phillips #00 screwdriver.
ある他の人がこのガイドを完成しました。
