必要な工具と部品
Flip over to the back side of the laptop
Remove the 10 screws at the bottom of the Razer using a T5 screwdriver head
Unplug the battery and wear the anti-static band before proceeding
Unscrew the six Philips screws around the battery and lift the battery
Find the SSD and unscrew the single screw
Once it is unscrewed, the SSD will pop up on one side
Carefully remove the SSD and place it to the side
Locate the two display cables to the left of the left speaker and disconnect both. (one is underneath the other)
Locate and disconnect the four cables
Disconnect one cable that is underneath the SSD
Disconnect another cable that is next to the right fan
Disconnect the final two cables that are to the left of the battery connector
Unscrew the four screws on the fans (two screws on each)
Make sure to unplug the connector on each of the fans. Lift and remove the fans.
Unscrew the four screws on the speakers (two screws on each)
Make sure to unplug the connector on each of the speakers and place them to the side
Remove the two screws on each hinge and pick up the black pieces
Locate the seven screws holding down the motherboard and remove them
Remove the plastic headphone jack cover
Lift up the MOBO and place it to the side
Unscrew the LCD
Slide the LCD connectors through the opening at the top when removing the LCD
Slide the LCD connectors of the new LCD through the opening at the top
Screw the new LCD back into the bottom case
Make sure all of the cables are in sight once the motherboard has been placed down
Screw in both the motherboard screws and the hinges
Reconnect the motherboard connectors
Place and screw in the fans and speakers
Make sure the SSD has been reconnected and screwed in
Screw the battery back in and reconnect the battery
Make sure all of the keys on the keyboard are working properly. Once done, call the user to pick up their laptop.
ある他の人がこのガイドを完成しました。
3 件のコメント
Hello. I have Razer blade 2019 model. On Web cant Finder keybord gór this exact model. Keybord from 2020 model will fit or there are diffrence in build ?
Is this for the RZ09-03006E92-R3U1?
Ryan Zmuda - 返信
