メインコンテンツにスキップ
Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement
必要な工具と部品
  1. Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Unfasten the back cover: 手順 1、 2の画像 1 Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Unfasten the back cover: 手順 1、 2の画像 2
    • Use a T5 Torx driver to remove the ten 3.8 mm‑long screws securing the back cover.
  2. Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Insert an opening pick: 手順 2、 3の画像 1 Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Insert an opening pick: 手順 2、 3の画像 2 Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Insert an opening pick: 手順 2、 3の画像 3
    • Depending on the age and condition of your laptop, the back cover may come off sooner than this guide instructs. If it feels loose, remove it at any time.
    • Apply a suction handle to the middle of the back cover's right edge, between the lower rubber foot and the middle screws.
    • Pull up on the suction handle to create a small gap between the back cover and the frame.
    • Insert an opening pick into the gap.
  3. Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Angle the opening pick: 手順 3、 3の画像 1 Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Angle the opening pick: 手順 3、 3の画像 2 Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Angle the opening pick: 手順 3、 3の画像 3
    • Angle your opening pick upward, away from the frame. Keep it angled upward as long as it's between the back cover and the frame.
  4. Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Free the bottom right corner: 手順 4、 3の画像 1 Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Free the bottom right corner: 手順 4、 3の画像 2 Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Free the bottom right corner: 手順 4、 3の画像 3
    • Slide your opening pick around the bottom right corner of the back cover to free it from the frame.
  5. Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Free the front edge: 手順 5、 3の画像 1 Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Free the front edge: 手順 5、 3の画像 2 Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Free the front edge: 手順 5、 3の画像 3
    • Slide your opening pick along the front edge and around the front left corner of the back cover to free it from the frame completely.
  6. Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Remove the back cover: 手順 6、 3の画像 1 Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Remove the back cover: 手順 6、 3の画像 2 Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Remove the back cover: 手順 6、 3の画像 3
    • Remove the back cover.
    • Lay the back cover down on its rubber feet to avoid damaging the thermal pads.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Spencer Day
メンバー登録日: 09/14/22
150,037 ポイント
995のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
23,648のガイドは作成済み
1件のガイドコメント
Buenas noches tu vendes la tapa trasera del Razer Blade 15 Advanced Model (Early 2020) RZ09-033
Germán Hernández - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 10
過去 30 日: 41
今までの合計 1,234
