メインコンテンツにスキップ
Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement
必要な工具と部品
  1. Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement, USB Port Board: 手順 1、 3の画像 1 Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement, USB Port Board: 手順 1、 3の画像 2 Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement, USB Port Board: 手順 1、 3の画像 3
    • Remove the four plastic covers and rubber feet from all four corners of the keyboard.
    • Remove the four screws.
    • Carefully pry around the bottom end of the keyboard and work your way around keyboard to un-clip the face.
  2. Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement: 手順 2、 2の画像 1 Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement: 手順 2、 2の画像 2
    • Turn the keyboard face up.
    • Remove the four screws which attach the keys.
    • Note the orientation of the white plastic cover relative to the LED at the bottom of the board.
  3. Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement: 手順 3、 1の画像 1
    • Locate the USB at the top of the device.
    • Remove the two screws attaching the USB.
  4. Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement: 手順 4、 2の画像 1 Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement: 手順 4、 2の画像 2
    • Unplug the cable connecting to the USB board.
    • Plug the new USB board into the slot.
    • Replace the screws in the USB board.
終わりに
ある他の人がこのガイドを完成しました。
作成者
9人の作成者と共同で作成されました。
Haleigh Teegarden
メンバー登録日: 01/17/17
329 ポイント
3のガイドは作成済み
チーム
Western Carolina University, Team 1-5, Virtue Spring 2017 Western Carolina University, Team 1-5, Virtue Spring 2017人のメンバー
WCU-VIRTUE-S17S1G5
4 メンバー
6のガイドは作成済み
4 件のコメント
hi, where do i get the new board from? thanks!
Doge The Best - 返信
You can easily find it on Ebay
Here's a link, i had the same issue
https://www.ebay.com/itm/272275162673htt...
iixroyal owlroyal -
Hey, you can easily Google the details on the USB board bottom left
I had the same issue
iixroyal owlroyal - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 37
今までの合計 5,013
