メインコンテンツにスキップ
Razer Blackwidow Tournament Edition Keyboard Metal Bar on Keys Replacement
必要な工具と部品
  1. Razer Blackwidow Tournament Edition Keyboard Metal Bar on Keys Replacement, Metal Bar on Keys: 手順 1、 1の画像 1
    • Before you do anything, take a picture of the entire keyboard so as to know where the keys go at the end.
    • Gently start to remove the keys surrounding the keys with the bars in them.
  2. Razer Blackwidow Tournament Edition Keyboard Metal Bar on Keys Replacement: 手順 2、 3の画像 1 Razer Blackwidow Tournament Edition Keyboard Metal Bar on Keys Replacement: 手順 2、 3の画像 2 Razer Blackwidow Tournament Edition Keyboard Metal Bar on Keys Replacement: 手順 2、 3の画像 3
    • Move the key itself off of one side of the bar from where it connects to easily allow the other side to be removed as well.
    • Another way to do it is to push the bar itself out gently with the metal spudger.
  3. Razer Blackwidow Tournament Edition Keyboard Metal Bar on Keys Replacement: 手順 3、 2の画像 1 Razer Blackwidow Tournament Edition Keyboard Metal Bar on Keys Replacement: 手順 3、 2の画像 2
    • Gently pop the bar out from its sockets.
    • Pop the new bar back into the sockets.
  4. Razer Blackwidow Tournament Edition Keyboard Metal Bar on Keys Replacement: 手順 4、 1の画像 1
    • Gently slide one side of the key into the bar and then use the metal spudger to pop the other side into place.
    • Use the picture from the beginning if necessary to make sure all the keys are in the right place.
終わりに
作成者
3人の作成者と共同で作成されました。
Haleigh Teegarden
メンバー登録日: 01/17/17
329 ポイント
3のガイドは作成済み
チーム
Western Carolina University, Team 1-5, Virtue Spring 2017 Western Carolina University, Team 1-5, Virtue Spring 2017人のメンバー
WCU-VIRTUE-S17S1G5
4 メンバー
6のガイドは作成済み
コメント 1 件
I bought my keyboard second hand have I either gotten a different keyboard or have the lad's been removed or is it a different model as I still have the Fn key which usually turns them on.
BettyBulldog123 a.k.a Betty - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 29
今までの合計 4,143
