メインコンテンツにスキップ
Razer Blackwidow Tournament Edition Chroma USB Port Board Replacement
必要な工具と部品
  1. Razer Blackwidow Tournament Edition Chroma USB Port Board Replacement, Rubber Feet: 手順 1、 2の画像 1 Razer Blackwidow Tournament Edition Chroma USB Port Board Replacement, Rubber Feet: 手順 1、 2の画像 2
    • Turn the keyboard over so that it is lying flat on its face.
    • Use the iFixit opening tool to pry the rubber feet off the keyboard.
  2. Razer Blackwidow Tournament Edition Chroma USB Port Board Replacement, Front Panel: 手順 2、 2の画像 1 Razer Blackwidow Tournament Edition Chroma USB Port Board Replacement, Front Panel: 手順 2、 2の画像 2
    • Use a Phillips #1 screwdriver to remove the six screws on the back of the keyboard.
    • Use an opening tool as a wedge between the front and back panel to pry open the front panel.
    • If the front and back panel won't separate, DO NOT use excessive force. This may result in damaging the keyboard.
    • Instead, slide the opening tool across the keyboard in between the front and back panel. Go around the edges of the keyboard until the panels disconnect.
    • Flip the keyboard over so the keys are facing up.
    • Grabbing the left and right lips of the front panel, lift both ends up, removing the front panel.
  3. Razer Blackwidow Tournament Edition Chroma USB Port Board Replacement, Back Panel: 手順 3、 2の画像 1 Razer Blackwidow Tournament Edition Chroma USB Port Board Replacement, Back Panel: 手順 3、 2の画像 2
    • Use a Philips #1 Screwdriver to remove the four screws located below the keys.
    • Lift the main circuit board and flip it over, placing it on its top.
    • Be cautious of the wire connected to the USB Port Board.
  4. Razer Blackwidow Tournament Edition Chroma USB Port Board Replacement, USB Port: 手順 4、 2の画像 1 Razer Blackwidow Tournament Edition Chroma USB Port Board Replacement, USB Port: 手順 4、 2の画像 2
    • Pull on the wire connector until it disconnects from the USB port board.
    • You may use either your hands or a pair of tweezers to separate the white connection clip.
終わりに
作成者
2人の作成者と共同で作成されました。
Jonathan Stewart
メンバー登録日: 02/08/18
301 ポイント
3のガイドは作成済み
チーム
University of North Texas, Team S6-G5, Thomas Spring 2018 University of North Texas, Team S6-G5, Thomas Spring 2018人のメンバー
UNT-THOMAS-S18S6G5
4 メンバー
13のガイドは作成済み
コメント 1 件
Where can I get another USB board? And it's possible to build one from scratch? I was thinking in upgrading to a USB C port
Eduwardo Horibe - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 14
今までの合計 1,917
