メインコンテンツにスキップ
Razer Blackwidow Tournament Edition Chroma Spacebar Metal Bar Replacement
必要な工具と部品
  1. Razer Blackwidow Tournament Edition Chroma Spacebar Metal Bar Replacement, Rubber Feet: 手順 1、 2の画像 1 Razer Blackwidow Tournament Edition Chroma Spacebar Metal Bar Replacement, Rubber Feet: 手順 1、 2の画像 2
    • Turn the keyboard over so that it is lying flat on its face.
    • Use the iFixit opening tool to pry the rubber feet off the keyboard.
  2. Razer Blackwidow Tournament Edition Chroma Spacebar Metal Bar Replacement, Front Panel: 手順 2、 2の画像 1 Razer Blackwidow Tournament Edition Chroma Spacebar Metal Bar Replacement, Front Panel: 手順 2、 2の画像 2
    • Use a Phillips #1 screwdriver to remove the six screws on the back of the keyboard.
    • Use an opening tool as a wedge between the front and back panel to pry open the front panel.
    • If the front and back panel won't separate, DO NOT use excessive force. This may result in damaging the keyboard.
    • Instead, slide the opening tool across the keyboard in between the front and back panel. Go around the edges of the keyboard until the panels disconnect.
    • Flip the keyboard over so the keys are facing up.
    • Grabbing the left and right lips of the front panel, lift both ends up, removing the front panel.
  3. Razer Blackwidow Tournament Edition Chroma Spacebar Metal Bar Replacement, Spacebar Metal Bar: 手順 3、 2の画像 1 Razer Blackwidow Tournament Edition Chroma Spacebar Metal Bar Replacement, Spacebar Metal Bar: 手順 3、 2の画像 2
    • Pinch the top and bottom of the key of the metal bar that you wish to replace and gently lift.
    • Tilt the key upwards so that you may see underneath it.
  4. Razer Blackwidow Tournament Edition Chroma Spacebar Metal Bar Replacement: 手順 4、 2の画像 1 Razer Blackwidow Tournament Edition Chroma Spacebar Metal Bar Replacement: 手順 4、 2の画像 2
    • Using tweezers unfasten the metal bar from the key both places that they are connected.
    • Using tweezers unfasten the metal bar from the keyboard itself both places that they are connected.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Jacob Hughes
メンバー登録日: 02/13/18
130 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team S6-G5, Thomas Spring 2018 University of North Texas, Team S6-G5, Thomas Spring 2018人のメンバー
UNT-THOMAS-S18S6G5
4 メンバー
13のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 17
過去 30 日: 74
今までの合計 7,063
