メインコンテンツにスキップ
Razer BlackWidow Chroma Back Panel Replacement
必要な工具と部品
  1. Razer BlackWidow Chroma Back Panel Replacement, Rubber Feet: 手順 1、 2の画像 1 Razer BlackWidow Chroma Back Panel Replacement, Rubber Feet: 手順 1、 2の画像 2
    • Turn the keyboard over so that it is lying flat on its face.
    • Use the iFixit opening tool to pry the rubber feet off the keyboard.
  2. Razer BlackWidow Chroma Back Panel Replacement, Front Panel: 手順 2、 2の画像 1 Razer BlackWidow Chroma Back Panel Replacement, Front Panel: 手順 2、 2の画像 2
    • Use a Phillips #1 screwdriver to remove the six screws on the back of the keyboard.
    • Use an opening tool as a wedge between the front and back panel to pry open the front panel.
    • If the front and back panel won't separate, DO NOT use excessive force. This may result in damaging the keyboard.
    • Instead, slide the opening tool across the keyboard in between the front and back panel. Go around the edges of the keyboard until the panels disconnect.
    • Flip the keyboard over so the keys are facing up.
    • Grabbing the left and right lips of the front panel, lift both ends up, removing the front panel.
  3. Razer BlackWidow Chroma Back Panel Replacement, Back Panel: 手順 3、 1の画像 1
    • Using a Phillips #1 screwdriver, remove all ten screws found along the outer edges of the keyboard.
  4. Razer BlackWidow Chroma Back Panel Replacement: 手順 4、 1の画像 1
    • Insert the Jimmy along the edges of the back panel and remove the back panel from the device.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Annika Grace Ford
メンバー登録日: 02/18/21
394 ポイント
3のガイドは作成済み
コメント 1 件
Lacks details on where the clips are. It resulted in prying an area where there was one and it broke. We need updated images with those details. If I can I will do do when I reassemble.
Kellic Normand - 返信
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 27
過去 30 日: 86
今までの合計 4,604
