メインコンテンツにスキップ
Razer Basilisk V3 Scroll Wheel Assembly Replacement
必要な工具と部品
  1. Razer Basilisk V3 Scroll Wheel Assembly Replacement, Skates: 手順 1、 1の画像 1
    • Locate each of the skates.
  2. Razer Basilisk V3 Scroll Wheel Assembly Replacement: 手順 2、 3の画像 1 Razer Basilisk V3 Scroll Wheel Assembly Replacement: 手順 2、 3の画像 2 Razer Basilisk V3 Scroll Wheel Assembly Replacement: 手順 2、 3の画像 3
    • Heat the skate using a heat gun or hair dryer.
    • Using the pointy end of the spudger pry away a corner of the skate.
    • If the adhesive does not pull away easily, heat the skate more.
    • Once the corner of the skate comes free use the flat end of the spudger to peel off the rest of the skate.
    • Repeat these steps for each of the skates.
  3. Razer Basilisk V3 Scroll Wheel Assembly Replacement, Backplate: 手順 3、 1の画像 1
    • Remove two 4.8 mm screws that were hidden under the skates using a JIS #1 screwdriver.
    • Remove the single 4 mm screw beneath the thumb grip using a JIS #1 screwdriver.
  4. Razer Basilisk V3 Scroll Wheel Assembly Replacement: 手順 4、 3の画像 1 Razer Basilisk V3 Scroll Wheel Assembly Replacement: 手順 4、 3の画像 2 Razer Basilisk V3 Scroll Wheel Assembly Replacement: 手順 4、 3の画像 3
    • Heat the label gently with a heat gun or hair dryer.
    • Once the adhesive is loosened, use a spudger to peel off the label carefully, revealing two additional screws.
    • Remove the two 4.8 mm screws using a JIS #1 screwdriver.
  5. Razer Basilisk V3 Scroll Wheel Assembly Replacement: 手順 5、 3の画像 1 Razer Basilisk V3 Scroll Wheel Assembly Replacement: 手順 5、 3の画像 2 Razer Basilisk V3 Scroll Wheel Assembly Replacement: 手順 5、 3の画像 3
    • Carefully pry apart the mouse's top and bottom halves. Using the iFixit opening tool, start at one corner and work around the edge.
    • Be cautious of the clips that may break during this process.
    • Using a plastic opening tool, gently pry the connector apart by moving side to side to avoid bending the pins.
    • When reassembling, be mindful that the connector only fits one way, as shown in the pictures.
  6. Razer Basilisk V3 Scroll Wheel Assembly Replacement, Scroll Wheel Assembly: 手順 6、 3の画像 1 Razer Basilisk V3 Scroll Wheel Assembly Replacement, Scroll Wheel Assembly: 手順 6、 3の画像 2 Razer Basilisk V3 Scroll Wheel Assembly Replacement, Scroll Wheel Assembly: 手順 6、 3の画像 3
    • Use the flat end of the spudger to pop-out the scroll wheel assembly.
    • Make sure you are careful when removing the assembly since it is still connected to the device with a ribbon cable. If you pull too hard the cable could break.
  7. Razer Basilisk V3 Scroll Wheel Assembly Replacement: 手順 7、 3の画像 1 Razer Basilisk V3 Scroll Wheel Assembly Replacement: 手順 7、 3の画像 2 Razer Basilisk V3 Scroll Wheel Assembly Replacement: 手順 7、 3の画像 3
    • Pull up on the top half of the cable connector and pull the cable from the connector.
    • The connection pins on the wire face towards the scroll wheel assembly housing. When reassembling, make sure the connectors on the cable are facing the correct direction.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Mary Quin
メンバー登録日: 03/20/24
252 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 1-2, Santin Spring 2024 UMass Dartmouth, Team 1-2, Santin Spring 2024人のメンバー
UMASSD-SANTIN-S24S1G2
3 メンバー
11のガイドは作成済み
コメント 1 件
Where can I buy this complete spare part?
Van4ESss - 返信
コメントを追加
統計データ:
過去 24時間: 10
過去 7 日: 74
過去 30 日: 338
今までの合計 2,392
