メインコンテンツにスキップ
Razer Basilisk V3 Backplate Replacement
必要な工具と部品
  1. Razer Basilisk V3 Backplate Replacement, Skates: 手順 1、 1の画像 1
    • Locate each of the skates.
  2. Razer Basilisk V3 Backplate Replacement: 手順 2、 3の画像 1 Razer Basilisk V3 Backplate Replacement: 手順 2、 3の画像 2 Razer Basilisk V3 Backplate Replacement: 手順 2、 3の画像 3
    • Heat the skate using a heat gun or hair dryer.
    • Using the pointy end of the spudger pry away a corner of the skate.
    • If the adhesive does not pull away easily, heat the skate more.
    • Once the corner of the skate comes free use the flat end of the spudger to peel off the rest of the skate.
    • Repeat these steps for each of the skates.
  3. Razer Basilisk V3 Backplate Replacement, Backplate: 手順 3、 1の画像 1
    • Remove two 4.8 mm screws that were hidden under the skates using a JIS #1 screwdriver.
    • Remove the single 4 mm screw beneath the thumb grip using a JIS #1 screwdriver.
  4. Razer Basilisk V3 Backplate Replacement: 手順 4、 3の画像 1 Razer Basilisk V3 Backplate Replacement: 手順 4、 3の画像 2 Razer Basilisk V3 Backplate Replacement: 手順 4、 3の画像 3
    • Heat the label gently with a heat gun or hair dryer.
    • Once the adhesive is loosened, use a spudger to peel off the label carefully, revealing two additional screws.
    • Remove the two 4.8 mm screws using a JIS #1 screwdriver.
  5. Razer Basilisk V3 Backplate Replacement: 手順 5、 3の画像 1 Razer Basilisk V3 Backplate Replacement: 手順 5、 3の画像 2 Razer Basilisk V3 Backplate Replacement: 手順 5、 3の画像 3
    • Carefully pry apart the mouse's top and bottom halves. Using the iFixit opening tool, start at one corner and work around the edge.
    • Be cautious of the clips that may break during this process.
    • Using a plastic opening tool, gently pry the connector apart by moving side to side to avoid bending the pins.
    • When reassembling, be mindful that the connector only fits one way, as shown in the pictures.
終わりに
作成者
3人の作成者と共同で作成されました。
Brendin Costa
メンバー登録日: 03/18/24
402 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team 1-2, Santin Spring 2024 UMass Dartmouth, Team 1-2, Santin Spring 2024人のメンバー
UMASSD-SANTIN-S24S1G2
3 メンバー
11のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 10
過去 7 日: 38
過去 30 日: 225
今までの合計 1,047
