はじめに
Before removing the crank arms, the pedals must be removed first. Follow this guide to the crank arms to replace the chain guard. To reassemble the crank arms and chain guard, follow steps in reverse order.
First take an 8 in adjustable crescent wrench and fit it around the base of the pedal.
Use a flathead screwdriver to remove the cap over the screw.
Do this for both sides.
If you are replacing the chain guard, use the new chain guard when reassembling the device.
