Make sure that the bike is upright and stable.
With both hands, place the rear rack on the rear wheel of the bike. Take note of where the rear rack will attach on the bike.
Make sure that the rear rack is fitted on the bike.
Place a screw to attach the rear rack to the frame of the tire.
Tighten the screw with a philips screwdriver by turning it in a clockwise direction.
Repeat the steps above on the other side of the bike.
Place the metal holder to be even with the bar sticking out of the rear rack.
Line up the holes. Place a bolt to attach them together.
Use a philips screwdriver to tighten the bolts.
Do this for both sides.
Make sure that the rear rack is even. If it is not, redo the previous step.
Locate the screws on top of the rear rack. Tighten the screws using a philips screwdriver.
Once the screws are tightened, you are done.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
