メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのRabbit R1を修理する際は、iFixitの修理ガイドをご利用ください。
  1. Rabbit R1 Teardown, Discharge and power off: 手順 1、 1の画像 1
    • It is good practice to discharge the battery before operating on a device. The Rabbit r1 is no different.
  2. Rabbit R1 Teardown, Heat up the back: 手順 2、 1の画像 1
    • Apply heat to the back of the unit with a tool of your choice to loosen the adhesive.
  3. Rabbit R1 Teardown, Remove the back panel: 手順 3、 1の画像 1
    • Using a razor blade or ifixit pick, slowly go around the unit. Be careful not to damage the plastic if you choose to use a razor blade.
    • Be careful when removing the back panel. The battery is attached to the back panel and connected via a ribbon cable.
  4. Rabbit R1 Teardown, A look inside: 手順 4、 1の画像 1
    • We now have access to the various insides of the Rabbit.
    • Inside, 6 screws attach a motherboard and a bracket. One of the screws is under a tamper resistant sticker.
  5. Rabbit R1 Teardown, Detaching connectors: 手順 5、 1の画像 1
    • Marked in blue are the connectors that will need to be removed.
  6. Rabbit R1 Teardown, PTT button.: 手順 6、 1の画像 1
    • After removing all the screws, the PTT button slides out of the chassis.
  7. Rabbit R1 Teardown, Removing the motherboard: 手順 7、 1の画像 1
    • After you disconnect all the ribbon cables and unscrew all the screws, the motherboard can be removed. Gently pull it out of the body of the Rabbit.
  8. Rabbit R1 Teardown, Removing the speaker: 手順 8、 2の画像 1 Rabbit R1 Teardown, Removing the speaker: 手順 8、 2の画像 2
    • The speaker is attached via clips and a screw. After removing the screw, slide the speaker toward the board and pull it up. Make sure to disconnect the speaker before removing it.
  9. Rabbit R1 Teardown, Magic Eye: 手順 9、 1の画像 1
    • To remove the magic eye, carefully take out the two screws and spacers that attach it. Then, gently pull the unit out.
  10. Rabbit R1 Teardown, Screen: 手順 10、 1の画像 1
    • Removing the screen is the same process as the back. Use heat and iFixit picks to loosen the adhesive and remove it from the body. Make sure to be careful with the ribbon cable that connects the LCD to the motherboard.
  11. Rabbit R1 Teardown, Teardown Complete: 手順 11、 1の画像 1
    • The Rabbit r1 is not designed for repairability, but it has some nice repair-friendly features, like using common screws and not too much glue.
作成者
3人の作成者と共同で作成されました。
William Urfer
メンバー登録日: 09/06/24
408 ポイント
2のガイドは作成済み
3件のガイドコメント
Perhaps you could use capitalization and punctuation?
Avni - 返信
Taken care of!
Preston Tech -
im too lazy to fix it my guy
William Urfer - 返信
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 30
過去 30 日: 86
今までの合計 1,481
