メインコンテンツにスキップ
RYOBI P422 Body Replacement
必要な工具と部品
  1. RYOBI P422 Body Replacement, Battery and Handle: 手順 1、 2の画像 1 RYOBI P422 Body Replacement, Battery and Handle: 手順 1、 2の画像 2
    • To remove the battery press down on the two buttons located on each side of the battery and pull away from the body of the grinder.
    • To remove the handle hold grinder with one hand and use the other hand to unscrew the handle with a counter-clockwise motion
  2. RYOBI P422 Body Replacement, Body: 手順 2、 1の画像 1
    • Lay the grinder flat on its side so the screws are facing up.
  3. RYOBI P422 Body Replacement: 手順 3、 3の画像 1 RYOBI P422 Body Replacement: 手順 3、 3の画像 2 RYOBI P422 Body Replacement: 手順 3、 3の画像 3
    • Remove the four 1.8 cm screws from the lower and mid section of the body with the Torx T20 screwdriver.
    • Remove the 3.7 cm screws from the upper section of the body, with the same screwdriver.
  4. RYOBI P422 Body Replacement: 手順 4、 2の画像 1 RYOBI P422 Body Replacement: 手順 4、 2の画像 2
    • Now that the two halves are unscrewed, lift up the top half.
  5. RYOBI P422 Body Replacement: 手順 5、 3の画像 1 RYOBI P422 Body Replacement: 手順 5、 3の画像 2 RYOBI P422 Body Replacement: 手順 5、 3の画像 3
    • Remove the safety trigger and the spring.
    • Be careful in removing the safety trigger, the pin may fall out as you are moving it.
  6. RYOBI P422 Body Replacement: 手順 6、 2の画像 1 RYOBI P422 Body Replacement: 手順 6、 2の画像 2
    • Lift up main trigger and spring together.
    • By lifting this trigger and spring out of the handle, you will pull double duty by lifting the black switch box off of its two support posts.
    • Slide the trigger off of the black switch box.
    • Be careful when removing trigger, the spring will be compressed and may move unexpectedly.
  7. RYOBI P422 Body Replacement: 手順 7、 3の画像 1 RYOBI P422 Body Replacement: 手順 7、 3の画像 2 RYOBI P422 Body Replacement: 手順 7、 3の画像 3
    この手順で使用する道具:
    購入する
    • Lift the battery lead bracket from its slot.
    • Use the PH 1 screwdriver to unscrew the two 0.7 cm screws that hold the 2.6 cm long brass bracket in place.
    • Use tweezers to remove the brass bracket.
    • During reassembly, remember to keep the spring inside the main trigger and against the bracket that is visible in the second of the accompanying photos.
  8. RYOBI P422 Body Replacement: 手順 8、 2の画像 1 RYOBI P422 Body Replacement: 手順 8、 2の画像 2
    • Flip the grinder over and lift off the second half of the body.
    • Now you can replace your damaged handles with a new pair.
終わりに
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
John Lamanuzzi
メンバー登録日: 03/20/15
229 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 3-6, Duarte Spring 2015 UMass Dartmouth, Team 3-6, Duarte Spring 2015人のメンバー
UMASSD-DUARTE-S15S3G6
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 1,410
