メインコンテンツにスキップ
RYDIS H68 Pro Side Brush Motor Replacement
必要な工具と部品
  1. RYDIS H68 Pro Side Brush Motor Replacement, Battery: 手順 1、 2の画像 1 RYDIS H68 Pro Side Brush Motor Replacement, Battery: 手順 1、 2の画像 2
    • Flip the vacuum over so that the wheels are facing you.
    • Use a Phillips #1 screwdriver to remove the four 10 mm screws that surround the battery cover.
  2. RYDIS H68 Pro Side Brush Motor Replacement: 手順 2、 1の画像 1
    • Lift the battery cover up to reveal the battery.
    • Remove the battery.
  3. RYDIS H68 Pro Side Brush Motor Replacement, Bumper: 手順 3、 3の画像 1 RYDIS H68 Pro Side Brush Motor Replacement, Bumper: 手順 3、 3の画像 2 RYDIS H68 Pro Side Brush Motor Replacement, Bumper: 手順 3、 3の画像 3
    • Remove the eight 10 mm Phillips #1 screws.
  4. RYDIS H68 Pro Side Brush Motor Replacement: 手順 4、 3の画像 1 RYDIS H68 Pro Side Brush Motor Replacement: 手順 4、 3の画像 2 RYDIS H68 Pro Side Brush Motor Replacement: 手順 4、 3の画像 3
    • Hold the front bumper and pull it off.
    • It requires a lot of force to pull the bumper off.
  5. RYDIS H68 Pro Side Brush Motor Replacement: 手順 5、 3の画像 1 RYDIS H68 Pro Side Brush Motor Replacement: 手順 5、 3の画像 2 RYDIS H68 Pro Side Brush Motor Replacement: 手順 5、 3の画像 3
    • Pry off the back bumper by going around the entire top of the bumper with the metal spudger.
  6. RYDIS H68 Pro Side Brush Motor Replacement, Side Brush Motor: 手順 6、 1の画像 1
    • Begin by unscrewing the 2 10mm screws using a Phillips #1 screwdriver.
    • Unlatch the latches indicated. It can be easily done with your finger.
    • Once unsecured, the covering for the sensors can easily be removed allowing access to the sensors.
    • The reason for these first few steps is to avoid damaging the signal wires for the sensor.
  7. RYDIS H68 Pro Side Brush Motor Replacement: 手順 7、 1の画像 1
    • This step just shows you how everything looks after the previous steps were completed.
    • There are sensors on both the left and right side. This can be done for either side.
  8. RYDIS H68 Pro Side Brush Motor Replacement: 手順 8、 1の画像 1
    • Unscrew the five 10mm screws using a Phillips #1 screwdriver.
  9. RYDIS H68 Pro Side Brush Motor Replacement: 手順 9、 1の画像 1
    • The side brush motor can now be removed by lifting it up.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
jude auguste
メンバー登録日: 02/15/17
108 ポイント
1ガイドが承認済み
チーム
USFT-Lacy-S17S005G2 USFT-Lacy-S17S005G2人のメンバー
Local Repair Groups
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 10
今までの合計 592
