メインコンテンツにスキップ
ROG Zephyrus G14 SSD and RAM Replacement
必要な工具と部品
  1. ROG Zephyrus G14 SSD and RAM Replacement, Opening The Laptop: 手順 1、 2の画像 1 ROG Zephyrus G14 SSD and RAM Replacement, Opening The Laptop: 手順 1、 2の画像 2
    • Flip over the laptop and locate all 14 of the screws. Follow the last image to find and remove all screws, noting the different sizes. *M2.5x6 doesn't get removed, marked in red.
    • 10 M2x9.5 Screws
    • 3 M2x4.5 Screws
    • 1 M2.5x6 Pop-Open Screw (do not remove)
    • Make sure device is completely powered off!
  2. ROG Zephyrus G14 SSD and RAM Replacement, Disconnect Battery: 手順 2、 2の画像 1 ROG Zephyrus G14 SSD and RAM Replacement, Disconnect Battery: 手順 2、 2の画像 2
    • Locate the battery connector, and unplug the battery to make sure you're safe before we continue. For this, slide the little chrome part back and lift the White plastic piece straight up
    • An anti-static wrist strap may be helpful to lower the risk of static discharge. (optional)
  3. ROG Zephyrus G14 SSD and RAM Replacement, RAM Replacement: 手順 3、 1の画像 1
    • To upgrade the RAM, peel the black cover on the right side to reveal the socket underneath.
    • Move the metal retention clip(s) by pushing down and outward
    • Insert the new module: look for the keying on the module and PCB. It can only be inserted one way.
    • Push down on the RAM like a hinge until the retention clip(s) grab onto the module.
  4. ROG Zephyrus G14 SSD and RAM Replacement, SSD Replacement: 手順 4、 2の画像 1 ROG Zephyrus G14 SSD and RAM Replacement, SSD Replacement: 手順 4、 2の画像 2
    • To replace the storage, locate the M.2 SSD under the longer black strip on the left.
    • Remove the screw holding it down. Proceed to pull the SSD out towards the outside of the chassis.
    • Slide the new SSD in making note of the keying as it may only be inserted one way (similar to RAM). You should be inserting it at a roughly 30-45 degree angle.
    • The G14 uses an M key slot. B-Key drives are unsupported. SATA drives (B + M) may work, but aren't recommended
    • Re-insert the screw to hold to new SSD in place.
  5. ROG Zephyrus G14 SSD and RAM Replacement, Battery: 手順 5、 1の画像 1
    • Put the plastic connector of the battery back on and slide the chrome piece back over it.
  6. ROG Zephyrus G14 SSD and RAM Replacement, Reassembly: 手順 6、 1の画像 1
    • Put the back cover on and put all the screws back
    • Around the top edge are a few plastic clips that should snap into place.
    • Make sure to put the screws back in the correct location to avoid accidental damage.
終わりに
When booting back up make sure to not freak out if it doesn’t start right away it does take a minute for the first boot up due to the laptop trying to register the new parts.
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Dylan Cervantes
メンバー登録日: 08/23/23
232 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team 3-93, Briggs Fall 2023 CSU Los Angeles, Team 3-93, Briggs Fall 2023人のメンバー
CSULA-BRIGGS-F23S3G93
1 メンバー
1のガイドは作成済み
2 件のコメント
Are both or just one RAM stick changeable?
C Sides - 返信
Just one is changeable. Sadly, the other is soldered to the board, so any upgrades will be in Single-Channel.
Phase -
コメントを追加
統計データ:
過去 24時間: 15
過去 7 日: 111
過去 30 日: 507
今までの合計 1,881
