必要な工具と部品
Remove the screws from the compartment cover, As show in the diagram, unscrew the screws labeled "A" first. before unscrewing "B", Don't remove screw "B" from the cover.
Locate the M.2 SSD slots, the First and Third slots both support SATA and PCIe NVMe M.2 SSDs, and the second M.2 Slot only supports PCIe NVMe SSDs
Next, Insert the NVMe SSD, and screw the SSD into place with the retaining screws
ある他の人がこのガイドを完成しました。
2 件のコメント
are the m.2 nvme slot PCIe 3.0x4 and are they all the same speed or type?
