このバージョンは誤った内容を含んでいる可能性があります。最新の承認済みスナップショットに切り替えてください。
分解
この分解は修理ガイドでは ありません。 お持ちのBlackBerry 7290を修理する際は、iFixitの修理ガイドをご利用ください。
この手順は未翻訳です。 翻訳を手伝う。
Apply pressure to the lock button on the back of the device.
Slide the battery cover down towards the bottom of the device, revealing the battery compartment.
Locate groove along the right side of the battery compartment.
Remove battery by prying between the battery and the groove.
Slide the SIM card holder to the left to unlock the SIM card.
Lift the SIM card holder up.
Gently remove the SIM card from the SIM card holder by sliding the card along the railing.
Locate the four screws along the perimeter of the back casing.
Remove the four top screws using a T-6 torx screwdriver.
The top four screws are .413 inches.
Locate two screws within the lower edge of the inner compartment.
Remove the two bottom screws using a T-6 torx screwdriver.
The bottom two screws are .2 inches in length.
The second picture displays the device after the six screws have been removed.
Use the plastic opening tool to apply pressure on the two clips that are located at the bottom of the phone.
Remove the back casing from the phone by lifting the unhooked portion, then slide the casing towards the top of the device.
Make sure all clips holding the case together are unhooked, so no damage is caused to the case.
Locate on the backside of the phone, a screw towards the top of the device.
Using a T-6 screwdriver, remove the screw.
After the screw has been removed, carefully lift the side button brace to reveal the side button.
To remove the phone's internals, start by loosening one side by pulling gently.
With one side loosened, simply lift the phone internals to separate from the front casing.
Turn the internals over to reveal the LCD display.
Peel off the rubber keypad buttons from the face plate.
Locate a hook on the right side of the internals below the volume wheel.
Use a plastic opening tool to gently pry the hook, separating the LCD display from the logic board mounting plate.
With the clip unhooked, gently separate the display from the phone internals by pulling.
On the front side of the internals, locate the the three screws that are highlighted in red.
Carefully remove screws from the internals, using a T6 torx screwdriver
The screw is .2 inches in length.
Separate the logic board mounting plate from the logic board by lifting with minimal force.
These are all the components of the phone.
6人の作成者と共同で作成されました。
メンバー登録日: 10/28/09
75 ポイント
1ガイドが承認済み
バッジ: 4
+1 以上のバッジ
CPSU-MANESS-F09S19G6
5 メンバー
7のガイドは作成済み
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
過去 24時間: 2
過去 7 日: 9
過去 30 日: 14
今までの合計 6,409
