はじめに
If your RIDGID R2740 Belt Sander won't turn on, the on/off switch may be defective and need to be replaced. This guide will walk you through how to replace the on/off switch on your RIDGID R2740 Belt Sander.
必要な工具と部品
Orient the belt sander so that the RIDGID logo is facing you.
Remove the six 19 mm and three 51 mm T20 screws that hold the cover into place.
Remove the cover from the belt sander.
Undo the two screws on the backside of the switch with a Phillips #3 screw driver.
ある他の人がこのガイドを完成しました。
