メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
How to take the top (yellow) and bottom (green) case halves off the RCX 1.0. Once you've taken off the case, you can clean the electrical contacts and replace any fried electronic components.
This guide is based on Kekoa Proudfoot's instructions on his RCX page, which includes two sentences of disassembly instructions and some photos.
パーツ
パーツは指定されていません。
  1. Place the RCX on a flat surface.
    • Place the RCX on a flat surface.
  2. Flip the RCX over so its black IR window is facing away from you.
    • Flip the RCX over so its black IR window is facing away from you.
  3. Remove the gray battery cover by lifting from the front (near the IR window). Raise it at an angle and remove it to reveal the green battery compartment.
    • Remove the gray battery cover by lifting from the front (near the IR window). Raise it at an angle and remove it to reveal the green battery compartment.
    • You can now remove the batteries and insert new ones.
  4. Nintendo Switch 修理キット
    ゲームを再開するための、早くて簡単な修理キット
    Switch 修理キットページへ
    Switch 修理キットページへ
  5. Remove the four screws in the battery compartment. These hold the yellow top on.
    • Remove the four screws in the battery compartment. These hold the yellow top on.
  6. Turn the RCX so the IR window points up. Pull the right side of the battery compartment away from the top case. The left side will be held in place by the battery clip.
    • Turn the RCX so the IR window points up.
    • Pull the right side of the battery compartment away from the top case. The left side will be held in place by the battery clip.
    • Lift the bottom of the black IR window. Pull it out.
  7. Hold the exposed edge of the circuit board with your fingers and pull the top case off, starting at the front. This takes considerable force. Make sure the case doesn't get stuck on the power connector on the back of the RCX.
    • Hold the exposed edge of the circuit board with your fingers and pull the top case off, starting at the front. This takes considerable force.
    • Make sure the case doesn't get stuck on the power connector on the back of the RCX.
  8. Hold the battery compartment and twist the circuit board counterclockwise.
    • Hold the battery compartment and twist the circuit board counterclockwise.
    • There is a little nub of plastic at each end of the battery compartment that you must lift the board over as you turn it.
  9. Remove the buttons from the top case. (They probably fell out already.) Squeeze the clips at the top and bottom of each Lego 9V connector. Push them through.
    • Remove the buttons from the top case. (They probably fell out already.)
    • Squeeze the clips at the top and bottom of each Lego 9V connector. Push them through.
終わりに
To reassemble your device, follow these instructions in reverse order. If you bent the battery clips when you removed the circuit board, bend them back down so they make contact with the solder on the board. The orientation of the gray battery cover doesn't matter.
8 の人々がこのガイドを完成させました。
notexactly
メンバー登録日: 2010年05月18日
324 ポイント
2のガイドは作成済み
3 件のコメント
As you can see, I was rushing when I did this guide. I'm planning to redo the disassembly next weekend and take landscape-oriented photos with better lighting and a white background.
notexactly - 返信
Guia simple y directa, justo lo que buscaba, Buen trabajo
Alejandro Castillo - 返信
It’s a GREAT guide, thank you! I bought an RCX off Ebay and found batteries inside that expired 6 years ago. You can imagine the corroded mess I’m cleaning up. Thanks to your guide I have it apart and cleaning.
Brian Wall - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 5,409
