はじめに
In order to replace parts inside the handset, it must be properly disassembled.
必要な工具と部品
Place your thumb in the groove on the back of handset. Next, push down with your thumb and then slide the battery cover towards the bottom of the phone to remove the battery cover.
Remove the four screws, located at each of the corners within the back encasing, with a small Phillips head screwdriver.
ある他の人がこのガイドを完成しました。
