はじめに
RCA Small Wonders Camcorder cc176 was manufactured in May 1993. Use this guide to remove and replace the speaker on this device.
  1. Remove the small black screws along the edges of the control panel on the top of the device. Pry off the top control panel using the plastic wedge tool. Remove the screw from the front, gray panel located beneath the "Scene Select AE" label.
    • Remove the small black screws along the edges of the control panel on the top of the device.
    • Pry off the top control panel using the plastic wedge tool.
    • Remove the screw from the front, gray panel located beneath the "Scene Select AE" label.
    • Remove the two small black screws on the top of the front, gray panel of the device, above the red AUTOFOCUS letters.
  2. Pro Tech ツールキットを含むご注文、もしくは総額 $100ドル以上のご注文については送料無料です。
    当社のショップを閲覧する
  3. Turn the device over and remove the two screws securing the front panel of the device.
    • Turn the device over and remove the two screws securing the front panel of the device.
    • Remove the screw securing the primary viewfinder, along the front of the camera.
    • Using a flat plastic tool, pry the entire front panel away from the device.
  4. Gently unplug the grey cord, located underneath the panel, disconnecting the speaker from the inner component of the device. Remove the speaker from the device.
    • Gently unplug the grey cord, located underneath the panel, disconnecting the speaker from the inner component of the device.
    • Remove the speaker from the device.
まとめ
Allison Baudoin
メンバー登録日: 2011年12月05日
401 ポイント
4のガイドは作成済み
チーム
James Madison, Team 2-1, Allen Fall 2011 James Madison, Team 2-1, Allen Fall 2011人のメンバー
JMU-ALLEN-F11S2G1
2 メンバー
4のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 722
