メインコンテンツにスキップ
RCA RCT6077W2 Battery, Motherboard, Speaker, and Antenna Replacement
必要な工具と部品
  1. RCA RCT6077W2 Battery, Motherboard, Speaker, and Antenna Replacement, Backplate: 手順 1、 2の画像 1 RCA RCT6077W2 Battery, Motherboard, Speaker, and Antenna Replacement, Backplate: 手順 1、 2の画像 2
    • Remove the two 2.5mm Phillips head screws before attempting to remove the screen from the device.
  2. RCA RCT6077W2 Battery, Motherboard, Speaker, and Antenna Replacement: 手順 2、 2の画像 1 RCA RCT6077W2 Battery, Motherboard, Speaker, and Antenna Replacement: 手順 2、 2の画像 2
    • Run an opening pick around the edge of the screen to loosen it and begin to pry upward.
    • When the screen comes up like it has in the photo, it should be able to simply be removed from its casing.
    • The buttons on the end of the device will be loose when you remove the screen from the backplate. Be careful not to lose them.
  3. RCA RCT6077W2 Battery, Motherboard, Speaker, and Antenna Replacement, Battery, Motherboard, Speaker, and Antenna: 手順 3、 1の画像 1
    • Remove the battery by first removing the electrical tape holding it down. Then begin gently prying underneath it and around the edges with your plastic opening tool, until the battery is loose.
  4. RCA RCT6077W2 Battery, Motherboard, Speaker, and Antenna Replacement: 手順 4、 1の画像 1
    • Remove the antenna by peeling back the tape holding the antenna to the casing.
  5. RCA RCT6077W2 Battery, Motherboard, Speaker, and Antenna Replacement: 手順 5、 2の画像 1 RCA RCT6077W2 Battery, Motherboard, Speaker, and Antenna Replacement: 手順 5、 2の画像 2
    • Unclip the ribbon cables from the motherboard by lifting up on their latches (the black portions that the cables feed into) and gently pulling the cables.
    • Do not use force to try and remove the cables. The latch may not be lifted up all the way, and using force can separate the cable from its connector. This can damage important components of the tablet.
  6. RCA RCT6077W2 Battery, Motherboard, Speaker, and Antenna Replacement: 手順 6、 2の画像 1 RCA RCT6077W2 Battery, Motherboard, Speaker, and Antenna Replacement: 手順 6、 2の画像 2
    • Remove the three 2.5mm Phillips screws from the motherboard.
    • After removing the screws, use a plastic opening tool to gently pull the motherboard off of the double-sided tape holding it down.
  7. RCA RCT6077W2 Battery, Motherboard, Speaker, and Antenna Replacement: 手順 7、 1の画像 1
    • Replace the removed unit with a suitable replacement, with all of the pictured parts.
    • When reassembling the device, be sure to put the speaker back into its slot in the casing before securing the backplate.
終わりに
To reassemble your device, follow these instructions in reverse order - replacing all tapes and adhesives as you proceed.
7 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Ryan Williams
メンバー登録日: 01/27/15
1,157 ポイント
4のガイドは作成済み
チーム
Pasco Hernando, Team 1-2, Prince Winter 2015 Pasco Hernando, Team 1-2, Prince Winter 2015人のメンバー
PHSC-PRINCE-W15S1G2
6 メンバー
8のガイドは作成済み
2 件のコメント
We did a reset. When our tablet boots up we get a message "google account manager has stopped running". We can not access the settings. How do we fix this error message?
southside80 - 返信
how about a screen that has lines
Sammy Finger - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 14
今までの合計 4,339
