メインコンテンツにスキップ
RCA Pro10 Edition Power/Volume Buttons Replacement
必要な工具と部品
  1. RCA Pro10 Edition Power/Volume Buttons Replacement, Speaker: 手順 1、 2の画像 1 RCA Pro10 Edition Power/Volume Buttons Replacement, Speaker: 手順 1、 2の画像 2
    • Using a separating tool, look for a seam in the plastic casing that looks most accessible.
    • Use the prying tool to separate the front and back casing, working your way around the perimeter.
    • Utilize a card tool or a pick to assist in keeping the case separated.
    • To reassemble the device simply align the two casing halves and pinch to snap together or press down on the edges while the device in on a table.
  2. RCA Pro10 Edition Power/Volume Buttons Replacement: 手順 2、 1の画像 1
    • Flip over the back of the device while keeping it close to the front, the speaker is attached to it.
    • Remove the yellow tape securing the speaker to the back casing.
  3. RCA Pro10 Edition Power/Volume Buttons Replacement: 手順 3、 2の画像 1 RCA Pro10 Edition Power/Volume Buttons Replacement: 手順 3、 2の画像 2
    • Use the separating tool to pry the speaker from its surface.
    • Use caution when removing the speaker, you may damage the screen.
    • Cut or desolder the wires to replace or repair the speaker.
  4. RCA Pro10 Edition Power/Volume Buttons Replacement, Camera: 手順 4、 3の画像 1 RCA Pro10 Edition Power/Volume Buttons Replacement, Camera: 手順 4、 3の画像 2 RCA Pro10 Edition Power/Volume Buttons Replacement, Camera: 手順 4、 3の画像 3
    • Using a P00 Phillips screwdriver, remove the three screws securing the black plastic camera housing and remove it.
    • Peel back the beige tape while holding down the camera ribbon cable to prevent tears
  5. RCA Pro10 Edition Power/Volume Buttons Replacement: 手順 5、 2の画像 1 RCA Pro10 Edition Power/Volume Buttons Replacement: 手順 5、 2の画像 2
    • Lift the locking tab that is securing the camera ribbon cable.
    • Slide the ribbon cable out from the connector and remove from casing.
  6. RCA Pro10 Edition Power/Volume Buttons Replacement, Power/Volume Buttons: 手順 6、 1の画像 1
    • Use a P00 Phillips screwdriver to remove the three screws securing the button board.
    • Desolder the contacts on the button board to remove or replace it.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Dayne Russell
メンバー登録日: 01/27/15
404 ポイント
4のガイドは作成済み
チーム
Pasco Hernando, Team 1-1, Prince Winter 2015 Pasco Hernando, Team 1-1, Prince Winter 2015人のメンバー
PHSC-PRINCE-W15S1G1
6 メンバー
10のガイドは作成済み
1件のガイドコメント
What is the part number for the Power/Volume Buttons? Where can I purchase one?
EvanSnow - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 12
今までの合計 1,148
