メインコンテンツにスキップ
RCA Pro10 Edition Display Screen Replacement
必要な工具と部品
  1. RCA Pro10 Edition Display Screen Replacement, Speaker: 手順 1、 2の画像 1 RCA Pro10 Edition Display Screen Replacement, Speaker: 手順 1、 2の画像 2
    • Using a separating tool, look for a seam in the plastic casing that looks most accessible.
    • Use the prying tool to separate the front and back casing, working your way around the perimeter.
    • Utilize a card tool or a pick to assist in keeping the case separated.
    • To reassemble the device simply align the two casing halves and pinch to snap together or press down on the edges while the device in on a table.
  2. RCA Pro10 Edition Display Screen Replacement: 手順 2、 1の画像 1
    • Flip over the back of the device while keeping it close to the front, the speaker is attached to it.
    • Remove the yellow tape securing the speaker to the back casing.
  3. RCA Pro10 Edition Display Screen Replacement: 手順 3、 2の画像 1 RCA Pro10 Edition Display Screen Replacement: 手順 3、 2の画像 2
    • Use the separating tool to pry the speaker from its surface.
    • Use caution when removing the speaker, you may damage the screen.
    • Cut or desolder the wires to replace or repair the speaker.
  4. RCA Pro10 Edition Display Screen Replacement, Camera: 手順 4、 3の画像 1 RCA Pro10 Edition Display Screen Replacement, Camera: 手順 4、 3の画像 2 RCA Pro10 Edition Display Screen Replacement, Camera: 手順 4、 3の画像 3
    • Using a P00 Phillips screwdriver, remove the three screws securing the black plastic camera housing and remove it.
    • Peel back the beige tape while holding down the camera ribbon cable to prevent tears
  5. RCA Pro10 Edition Display Screen Replacement: 手順 5、 2の画像 1 RCA Pro10 Edition Display Screen Replacement: 手順 5、 2の画像 2
    • Lift the locking tab that is securing the camera ribbon cable.
    • Slide the ribbon cable out from the connector and remove from casing.
  6. RCA Pro10 Edition Display Screen Replacement, Power/Volume Buttons: 手順 6、 1の画像 1
    • Use a P00 Phillips screwdriver to remove the three screws securing the button board.
    • Desolder the contacts on the button board to remove or replace it.
  7. RCA Pro10 Edition Display Screen Replacement, Battery: 手順 7、 2の画像 1 RCA Pro10 Edition Display Screen Replacement, Battery: 手順 7、 2の画像 2
    • Peel off the black tape on the battery and main-board.
    • Peel off the black tape securing the screen ribbon cable to the back of the screen.
    • Use caution to avoid damaging either ribbon cable.
  8. RCA Pro10 Edition Display Screen Replacement: 手順 8、 2の画像 1 RCA Pro10 Edition Display Screen Replacement: 手順 8、 2の画像 2
    • Slide out the ribbon cable lock that is securing the screen ribbon cable.
    • Move the ribbon cable out of the way using tape if necessary.
  9. RCA Pro10 Edition Display Screen Replacement: 手順 9、 2の画像 1 RCA Pro10 Edition Display Screen Replacement: 手順 9、 2の画像 2
    この手順で使用する道具:
    Plastic Cards
    $2.99
    • Remove the yellow tape securing the battery to the screen.
    • Use a plastic card or pick to separate the battery from the screen.
    • Do not bend or puncture battery, battery is difficult to separate from screen.
    • Cut or desolder the wires on the battery to remove or replace it.
  10. RCA Pro10 Edition Display Screen Replacement, Display Screen: 手順 10、 1の画像 1
    • Peel the WiFi antenna off of the monitor and move out of the way.
  11. RCA Pro10 Edition Display Screen Replacement: 手順 11、 3の画像 1 RCA Pro10 Edition Display Screen Replacement: 手順 11、 3の画像 2 RCA Pro10 Edition Display Screen Replacement: 手順 11、 3の画像 3
    • Remove the black tape on the screen and the main-board.
    • Lift the ribbon cable lock securing the digitizer ribbon cable.
    • Slide out the digitizer ribbon cable and move away from the device, use tape to secure if necessary.
  12. RCA Pro10 Edition Display Screen Replacement: 手順 12、 1の画像 1
    • Use a P00 Phillips screwdriver to remove the three screws securing the main-board to the back casing.
  13. RCA Pro10 Edition Display Screen Replacement: 手順 13、 3の画像 1 RCA Pro10 Edition Display Screen Replacement: 手順 13、 3の画像 2 RCA Pro10 Edition Display Screen Replacement: 手順 13、 3の画像 3
    この手順で使用する道具:
    • Lift the main-board up and away from the ports to reveal the microphone.
    • Use tweezers to remove the microphone from the black silicone.
    • Move the main-board off the screen.
  14. RCA Pro10 Edition Display Screen Replacement: 手順 14、 2の画像 1 RCA Pro10 Edition Display Screen Replacement: 手順 14、 2の画像 2
    • Use a separator tool to lift the screen from the port side of the casing and remove it.
    • To reassemble the device, follow these steps in reverse unless specified otherwise.
終わりに
9 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Tyler Schuster
メンバー登録日: 01/27/15
476 ポイント
1ガイドが承認済み
チーム
Pasco Hernando, Team 1-1, Prince Winter 2015 Pasco Hernando, Team 1-1, Prince Winter 2015人のメンバー
PHSC-PRINCE-W15S1G1
6 メンバー
10のガイドは作成済み
4件のガイドコメント
Gracias y ademas la buenas fotografias ayudaron una inmesidad.
Kl
Klaus laage - 返信
Nothing spectacular happened I just turned on my tablet today and voila! My display is crazed on part of the screen! I read these steps a couple times and I just don't understand how if this process is intended to replace the display screen a display screen isn't listed as a necessary part purchase. I have faith in reader generated sites so please help!
Denise Engle - 返信
Denise a new display screen would need to be purchased. Unless you absolutely have to have this particular tablet fixed I suggest buying a new one.
Chris Blackwell -
hola, podrás tener este repuesto de la pantalla lcd para la venta para ese modelo?
gracias
William Weygel
williamw666@hotmail.com
William Weygel - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 16
今までの合計 6,413
