はじめに
Outline what you are going to teach someone how to do.
必要な工具と部品
Using a separating tool, look for a seam in the plastic casing that looks most accessible.
Use the prying tool to separate the front and back casing, working your way around the perimeter.
Utilize a card tool or a pick to assist in keeping the case separated.
Peel off the black tape on the battery and main-board.
Peel off the black tape securing the screen ribbon cable to the back of the screen.
この手順で使用する道具:Plastic Cards$2.99
Remove the yellow tape securing the battery to the screen.
Use a plastic card or pick to separate the battery from the screen.
Cut or desolder the wires on the battery to remove or replace it.
10 の人々がこのガイドを完成させました。
