メインコンテンツにスキップ
RCA Pro10 Edition Battery Replacement
必要な工具と部品
  1. RCA Pro10 Edition Battery Replacement, Speaker: 手順 1、 2の画像 1 RCA Pro10 Edition Battery Replacement, Speaker: 手順 1、 2の画像 2
    • Using a separating tool, look for a seam in the plastic casing that looks most accessible.
    • Use the prying tool to separate the front and back casing, working your way around the perimeter.
    • Utilize a card tool or a pick to assist in keeping the case separated.
    • To reassemble the device simply align the two casing halves and pinch to snap together or press down on the edges while the device in on a table.
  2. RCA Pro10 Edition Battery Replacement: 手順 2、 1の画像 1
    • Flip over the back of the device while keeping it close to the front, the speaker is attached to it.
    • Remove the yellow tape securing the speaker to the back casing.
  3. RCA Pro10 Edition Battery Replacement: 手順 3、 2の画像 1 RCA Pro10 Edition Battery Replacement: 手順 3、 2の画像 2
    • Use the separating tool to pry the speaker from its surface.
    • Use caution when removing the speaker, you may damage the screen.
    • Cut or desolder the wires to replace or repair the speaker.
  4. RCA Pro10 Edition Battery Replacement, Battery: 手順 4、 2の画像 1 RCA Pro10 Edition Battery Replacement, Battery: 手順 4、 2の画像 2
    • Peel off the black tape on the battery and main-board.
    • Peel off the black tape securing the screen ribbon cable to the back of the screen.
    • Use caution to avoid damaging either ribbon cable.
  5. RCA Pro10 Edition Battery Replacement: 手順 5、 2の画像 1 RCA Pro10 Edition Battery Replacement: 手順 5、 2の画像 2
    • Slide out the ribbon cable lock that is securing the screen ribbon cable.
    • Move the ribbon cable out of the way using tape if necessary.
  6. RCA Pro10 Edition Battery Replacement: 手順 6、 2の画像 1 RCA Pro10 Edition Battery Replacement: 手順 6、 2の画像 2
    この手順で使用する道具:
    Plastic Cards
    $2.99
    購入する
    • Remove the yellow tape securing the battery to the screen.
    • Use a plastic card or pick to separate the battery from the screen.
    • Do not bend or puncture battery, battery is difficult to separate from screen.
    • Cut or desolder the wires on the battery to remove or replace it.
終わりに
10 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Dayne Russell
メンバー登録日: 01/27/15
401 ポイント
4のガイドは作成済み
チーム
Pasco Hernando, Team 1-1, Prince Winter 2015 Pasco Hernando, Team 1-1, Prince Winter 2015人のメンバー
PHSC-PRINCE-W15S1G1
6 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 20
今までの合計 15,943
