はじめに
The volume button turns up and down the volume on the RCA Maven Pro 11. If the button becomes damaged and will no longer press down this guide can be utilized to remove and replace it.
必要な工具と部品
Locate the volume button on the inside of the cover.
Slide a wedge between the cover and the volume button and lightly lift it off.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
