メインコンテンツにスキップ
RCA Lyra X2400 flash card reader replacement
必要な工具と部品
  1. RCA Lyra X2400 flash card reader replacement, Battery: 手順 1、 3の画像 1 RCA Lyra X2400 flash card reader replacement, Battery: 手順 1、 3の画像 2 RCA Lyra X2400 flash card reader replacement, Battery: 手順 1、 3の画像 3
    • Using slight pressure with your finger on the word "OPEN", slide the battery plate down.
    • Remove the battery plate.
    • Place your finger at the bottom of the battery.
    • Lift up on the battery until it pops out from the LYRA X2400.
  2. RCA Lyra X2400 flash card reader replacement, Screen: 手順 2、 2の画像 1 RCA Lyra X2400 flash card reader replacement, Screen: 手順 2、 2の画像 2
    • Remove the two Phillips screws from the silver cover at the top of the Lyra.
    • Slowly wiggle the silver cover while pulling it away from the device.
  3. RCA Lyra X2400 flash card reader replacement: 手順 3、 2の画像 1 RCA Lyra X2400 flash card reader replacement: 手順 3、 2の画像 2
    • Remove the two Phillips screws from the bottom of the device, next to the charger port and Compact Flash release button.
    • Pull the silver case from the bottom of the device.
  4. RCA Lyra X2400 flash card reader replacement: 手順 4、 3の画像 1 RCA Lyra X2400 flash card reader replacement: 手順 4、 3の画像 2 RCA Lyra X2400 flash card reader replacement: 手順 4、 3の画像 3
    • Carefully pry up the screen with a plastic opening tool.
    • Disconnect the screen's ribbon cable from the circuit board.
    • Remove the screen.
  5. RCA Lyra X2400 flash card reader replacement, Motherboard: 手順 5、 2の画像 1 RCA Lyra X2400 flash card reader replacement, Motherboard: 手順 5、 2の画像 2
    • Open the case of the Lyra.
    • Remove the four screws that secure the motherboard to the frame of the Lyra X2400.
  6. RCA Lyra X2400 flash card reader replacement, Compact Flash Card: 手順 6、 2の画像 1 RCA Lyra X2400 flash card reader replacement, Compact Flash Card: 手順 6、 2の画像 2
    • Locate the compact flash card slot on the logic board. For assistance on locating this component look at the picture to the left.
    • Use soldering/desoldering tools to remove the compact flash card.
    • Replace compact flash card and use soldering tools to complete the replacement.
終わりに
作成者
4人の作成者と共同で作成されました。
Joseph Goodwin
メンバー登録日: 04/11/13
1 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 17-3, Regan Spring 2013 Cal Poly, Team 17-3, Regan Spring 2013人のメンバー
CPSU-REGAN-S13S17G3
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 226
