Slide a spudger between the plastic rail and the metal tab on the left side of the rail. Push away from the camcorder to release the flap.
Pushing the viewfinder assembly to the right makes lifting the flap easier.
Slide the lifted flap towards the viewfinder assembly until the viewfinder is free from the rail.
Unscrew the 7mm ph#0 screw on the underside where the cable connects.
Lift the plastic where the cable connects off of the viewfinder assembly.
Disconnect the cable inside by pulling it apart.
Lift off both sides of the plastic assembly.
When reassembling, if the housing doesn't connect properly, try turning the focus wheel.
Lift plastic housing and guide the wires from underneath.
Lift out the entire circuit board and viewfinder.
Replace entire circuit board and viewfinder assembly.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
