メインコンテンツにスキップ
RCA CC310 Onboard Speaker Replacement
必要な工具と部品
  1. RCA CC310 Onboard Speaker Replacement, Disassembling RCA CC310 Left Cover: 手順 1、 2の画像 1 RCA CC310 Onboard Speaker Replacement, Disassembling RCA CC310 Left Cover: 手順 1、 2の画像 2
    • Remove the six 7.9mm Phillips #0 screws on the back and bottom.
    • Remove the one 3.8mm Phillips #0 screw on the bottom.
    • Remove the two 7.5mm Phillips #0 screws on the back and bottom.
  2. RCA CC310 Onboard Speaker Replacement: 手順 2、 2の画像 1 RCA CC310 Onboard Speaker Replacement: 手順 2、 2の画像 2
    • Remove 5.8mm Phillips #1 screw from the side button panel.
    • Slide the viewfinder all the way to the right and remove the 7.9mm Phillips #0 screw.
  3. RCA CC310 Onboard Speaker Replacement: 手順 3、 2の画像 1 RCA CC310 Onboard Speaker Replacement: 手順 3、 2の画像 2
    • Pry along the seam on the top side near the buttons with a spudger.
  4. RCA CC310 Onboard Speaker Replacement: 手順 4、 2の画像 1 RCA CC310 Onboard Speaker Replacement: 手順 4、 2の画像 2
    • Pull the left panel away from the rest of the camcorder.
    • Unplug the red speaker cable located at the rear of the device.
    • Be careful to not pull too hard. The speaker cable is still connected to the panel and it can rip.
  5. RCA CC310 Onboard Speaker Replacement, Onboard Speaker: 手順 5、 2の画像 1 RCA CC310 Onboard Speaker Replacement, Onboard Speaker: 手順 5、 2の画像 2
    • Unplug the red cable connecting the speaker to the motherboard.
  6. RCA CC310 Onboard Speaker Replacement: 手順 6、 2の画像 1 RCA CC310 Onboard Speaker Replacement: 手順 6、 2の画像 2
    • Locate the speaker on the removed panel. Find the groove on the top left side of the speaker.
    • Pry the plastic up with a spudger until the glue breaks and the speaker is detached.
  7. RCA CC310 Onboard Speaker Replacement: 手順 7、 1の画像 1
    • Break the plastic pieces holding the cable to the panel.
    • Glue the new cables, with a hot glue gun, back to the panel after replacing the speaker.
  8. RCA CC310 Onboard Speaker Replacement: 手順 8、 3の画像 1 RCA CC310 Onboard Speaker Replacement: 手順 8、 3の画像 2 RCA CC310 Onboard Speaker Replacement: 手順 8、 3の画像 3
    • Glue the new speaker to the panel.
    • Plug the cable back into the motherboard.
終わりに
作成者
6人の作成者と共同で作成されました。
Oliver Adams
メンバー登録日: 01/19/11
629 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 5-20, Amido Winter 2011 Cal Poly, Team 5-20, Amido Winter 2011人のメンバー
CPSU-AMIDO-W11S5G20
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 995
