はじめに
This guide will instruct you to replace the effect button circuit board on the RCA CC310.
必要な工具と部品
Remove the six 7.9mm Phillips #0 screws on the back and bottom.
Remove the one 3.8mm Phillips #0 screw on the bottom.
Remove the two 7.5mm Phillips #0 screws on the back and bottom.
Unplug the two cables on the bottom of the effect button circuit board.
Unplug the cable at the top left side of the motherboard.
ある他の人がこのガイドを完成しました。
